Pics of Blown HGs? - TCCoA Forums
post #1 of 12 (permalink) Old 02-25-2008, 02:19 PM Thread Starter
winkeytoofly's Avatar
Pics of Blown HGs?
Anyone have pictures of blown Head Gaskets?
Im going junk yard shopping for a 3.8 and im gonna be tearing the blocks apart before i decide on the one im taking home so i want to be able to spot ones that are there because of HG issues.
winkeytoofly is offline
post #2 of 12 (permalink) Old 02-25-2008, 04:52 PM
SC V8 Bird's Avatar
Send a message via Yahoo to SC V8 Bird
Holy crap, you plan on tearing every one down to the block to decide?
You have way more time to do that than I do.
I don't have any pics but if you tear it down to the block and inspect the gasket it will be obvious where the gasket material has blown out.
There will be a piece missing that should obviously be there next to the water jackets.
If you are buying a 3.8 block and tearing the heads off you will have to replace the headgaskets anyway so what difference does it make if the gaskets were blown other than if someone ran it like that and ruined the motor. I wouldn't replace any 3.8 without upgrading to Felpro gaskets.
Here is an example I found on the net, not a 3.8 gasket but the failures look the same
SC V8 BIRD
TCCoA Gallery
http://forums.tccoa.com/vbpicgallery.php?do=view&g=45
Car Domain
http://www.cardomain.com/ride/2527375
NW Late Model Thunderbirds & Supercoupes Myspace Group
http://groups.myspace.com/nwlatemodelthunderbirds
SC V8 Bird is offline
post #3 of 12 (permalink) Old 02-26-2008, 08:20 AM Thread Starter
LoL i dont really have that kinda time but id rather make a safe buy then buy the block get it back home only to find that i have a block with warped heads and then have to bring it back and get a new one.
Also taking a day off way in advance and im gonna have 2 of my buddies that own me a favor come along so it really shouldnt take to long.
The main reason i wanted pictures was so i could show my friends what we are trying to avoid.
And ya i know if im tearing it apart i have to replace them any way but im gonna to be extremly picky, if i find one with even a hint of a blown gasket im moving on to the next bird.
PS.
Thanks a Bunch for the link
post #4 of 12 (permalink) Old 02-26-2008, 08:44 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
hold on, you need to see if the heads are good. they usually crack. the blocks are pretty stout. unless you are certain your heads are bad, take the heads you have to a machine shop and have them check them for cracks. do this first. if one is cracked, then its time to hit up the boneyard.
of the three 3.8s that i have seen blow a hg, its always the back passenger side cylinder where the gasket fails.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 12 (permalink) Old 02-26-2008, 09:28 AM
jco1385's Avatar
this is true with mine. #3 i think
jco1385 is offline
post #6 of 12 (permalink) Old 02-26-2008, 10:04 AM
cmill95's Avatar
when you have an engine rebuilt, the machine shop SHOULD deck the heads anyway to be sure that you have a perfectly flat mounting surface. this is a good time to think about compression ratios. 10-1 would be attainable with some surfacing. maybe bigger valves too, just make sure that they use what's been called a "bowl-hog"(I'm pretty sure that's not a technical term, but what a buddy of mine called it). it opens up the area for a bigger valve while unshruoding the rear of the intake/exhaust ports.
to be popping that many sets of heads off to find a good head/block set-up, you gotta have one of those battery powered impact guns, yeah?
cmill95 is offline
post #7 of 12 (permalink) Old 02-26-2008, 12:55 PM
Silenced's Avatar
Might be easier to check the coolant for oil and oil for coolant first.
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #8 of 12 (permalink) Old 02-26-2008, 01:53 PM
13's or Mildly Broken
Depending on the yard, that may be drained before it gets parked in the yard, so to speak.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #9 of 12 (permalink) Old 02-26-2008, 02:21 PM Thread Starter
Ya all the yards around me drain fluids otherwise id take the easy way and check those.
But the nice thing is that most of them put the cars on stands so taking stuff off is a simple
post #10 of 12 (permalink) Old 02-27-2008, 08:11 AM
Heres a picture I took that shows where the gasket material is missing between cylinder and coolant passage.
Mark
My nest: 93 White 5.0-- 94 Green 4.6-- 96 Green 3.8 --97 Red 4.6 limited edition---95 SC 5 speed
mkbrower is offline
post #11 of 12 (permalink) Old 02-27-2008, 01:51 PM
You can also see that the piston is much cleaner on the cylinder where the head gasket blew. That's a tell-tale sign.
post #12 of 12 (permalink) Old 02-27-2008, 03:43 PM
SC V8 Bird's Avatar
Hey Wow! Steam cleaning! I think you are on to something, now if we could just figure out a way to market this. Hmmm.
SC V8 BIRD
TCCoA Gallery
Car Domain
