losing coolant in 3.8, pictures - TCCoA Forums
post #1 of 25 (permalink) Old 03-02-2008, 06:33 PM Thread Starter
richuncle's Avatar
Hey all. So finally everything lined up today for me to look for my coolant leak. Laziness was my biggest problem. Anyways any one have any hints as to where the leak is? I couldn't really tell, and am not familiar with the coolant system. I have never changed a thermostat. That's why I am on the newbie forum. Any ideas?
Here is the top of one of the sensors: There was coolant on the bottom and the cable looks a little bulged.
The view from the front:
Some background: I have to refill the reservoir every week or so. I had my mechanic flush by system a while ago and this problem seemed to happen at the same time. Seems to be getting worse.
Also any ideas what is going on here:
I think my AC is leaking, but I am not sure what those things are.
richuncle is offline
post #2 of 25 (permalink) Old 03-02-2008, 08:05 PM
I maybe wrong but it looks like there is coolant around the water pump area. I would check to see if it is leaking there. That is the only thing i see so far.
tino is offline
post #3 of 25 (permalink) Old 03-02-2008, 08:06 PM
Oh i almost forgot it could be the timing cover , what the dealer calls the front engine cover gasket. I had that done under recall a while back.
tino is offline
post #4 of 25 (permalink) Old 03-02-2008, 08:56 PM
white lincoln's Avatar
-disregard-
white lincoln is offline
post #5 of 25 (permalink) Old 03-03-2008, 08:03 AM Thread Starter
richuncle's Avatar
Yeah the thing is I couldn't see very well, too much stuff in the way. I guess the suggestion would be to start tearing some stuff off and having a better look? Once I start pulling the intake manifold I will need to replace the gaskets right?
post #6 of 25 (permalink) Old 03-03-2008, 10:40 AM
-disregard-
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
post #7 of 25 (permalink) Old 03-03-2008, 10:57 AM
Looks like your coolant sensor hose is leaking. You may want to try tightening it first to see if that helps.
This connection:
post #8 of 25 (permalink) Old 03-03-2008, 11:11 AM
-disregard-
post #9 of 25 (permalink) Old 03-03-2008, 11:31 AM
Rolling-Thunder's Avatar
white lincoln - He has a 3.8 v6 - why the 4.6 v8 diagram and discussion ?
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #10 of 25 (permalink) Old 03-03-2008, 11:38 AM
Ya... I knew that... I was just testing you guys to see if you were paying attention...
Crap, I just noticed that he had 6 connections on the electronic ignition... jeez, what a chump.
post #11 of 25 (permalink) Old 03-03-2008, 11:52 AM
rich uncle - you're best bet right now - other than taking it back to the mechanic that did the flush - might be to wipe off all the visible coolant from your engine, and then start the car and watch to see where it is coming from. It is not possible to determine where it is leaking based on these photographs.
post #12 of 25 (permalink) Old 03-03-2008, 11:59 AM Thread Starter
richuncle's Avatar
Thanks for the suggestions. I would take it back to my mechanic but I moved.
I will take a better look this weekend. I was just checking to see if it was an obvious problem. Like "oh you have liquid in that area, it's most likely ...". I will let you guys know how it goes.
post #13 of 25 (permalink) Old 03-03-2008, 12:02 PM
Ya, try tightening the clamp on that hose for the sensor and see if the leaking stops. You can go real tight on those hose clamps. Pour some water around the area to get the coolant that is there out so you can see if it comes back after tightening the clamp. Maybe the guy used that hose to flush the system?
As for the AC, clean off those areas with some gunk cleaner or something that removes grease, have the pressure of the AC system checked and see if it lost coolant and if the leaking persists (after cleaning the lines).
post #14 of 25 (permalink) Old 03-24-2008, 08:28 PM Thread Starter
richuncle's Avatar
well I tightened the hose clamp and it still leaks. I think it leaks where that tube connecting to the manifold.
I was at a pull a part for an unrelated thing and I saw a 3.8L in a mustang with the same tube (the one with the sensor on the top and the line going to the heater core). I could not for the life of me get that thing off. I didn't have the right tools though...big leverage pipe, hammer, etc. Then I figured "what am I doing maybe I should just take the whole manifold. Well, I was a little in over my head. I got stuck at the fuel rail and figured I took too much time and left it.
oh by the way, just curious..lets say i needed to replace the flexible piece of hose that runs from the tube to the hard line going to the heater core. Would I need to replace the hard line to?
post #15 of 25 (permalink) Old 03-25-2008, 12:42 PM
jco1385's Avatar
that looks EXACTLY like mine when i had to replace the timing cover gasket.
jco1385 is offline
post #16 of 25 (permalink) Old 03-25-2008, 01:00 PM
Send a message via Yahoo to ThunderRoad
Cool I Believe Your Right!!!!!!!!!!!
IT LOOKS TO BE A TIMING CASE GASKET WHAT PITA TO DO TRY TIGHTING ALL THE BOLTS A TWEAK AND ADD THE DRY POWDED SEALEANT AS WELL IT SOMETIME DOES THE TRICK IF NOT MUCH WORCK TO DO
ThunderRoad is offline
post #17 of 25 (permalink) Old 03-25-2008, 01:43 PM
jco1385's Avatar
actually it's not that bad to do, if it is the timing cover gasket.
i suggest DO NOT try to tighten the bolts. i did this and one snapped in the block. now that makes it a bich.
pretty straight forward process. remove the belt, p/s pump (and bracket), waterpump, and the the cover comes off. that is IIRC.
here's the thread from when i did mine: http://forums.tccoa.com/showthread.php?t=100845
jco1385 is offline
post #18 of 25 (permalink) Old 03-25-2008, 05:39 PM
I would not suggest the powder sealant. I have had it seal, and then plug things up later and equal more work that it was worth.
I'd fix it right the first (and last) time.
Svtbrd is offline
post #19 of 25 (permalink) Old 03-26-2008, 12:22 AM
You can cut off the crimp and remove the section of rubber hose, then run new hose with hose clamps.
post #20 of 25 (permalink) Old 03-28-2008, 08:05 AM
My '95 Cougar does the same thing dammit! Mine is more of a seeping at this point but I suspect it will get worse.
Virginia Donkey is offline
post #21 of 25 (permalink) Old 03-28-2008, 08:18 AM Thread Starter
richuncle's Avatar
I've had this leak for a little over a year. It really hasn't got any worse but it is getting really annoying to fill up the reservoir every other week. Especially when I am late for work.
post #22 of 25 (permalink) Old 03-28-2008, 08:38 AM
jco1385's Avatar
well it may not be bad at this point but remember that these engines are prone to HG failure. It really isnt hard to fix and it may be worth it in the long run.
and please do not use any "quick fix" method.
jco1385 is offline
post #23 of 25 (permalink) Old 04-04-2008, 05:45 AM
I had that same leak a few months back. You need to change your gasket where your thermastat is. That should hopefully fit your probelm. Mine hasn't leaked since.
Deadly is offline
post #24 of 25 (permalink) Old 04-04-2008, 11:58 AM
A t-stat housing leak probably wouldn't end up dripping down the passenger side of the timing cover.
post #25 of 25 (permalink) Old 04-04-2008, 04:21 PM
no but it would cause that puddle visible in the second picture because thats exactly where mine was building up at.
Deadly is offline
