Engine Knock After Oil Changes - TCCoA Forums
post #1 of 24 (permalink) Old 03-10-2008, 03:47 PM Thread Starter
Is there any way to prevent the knock that occurs for a few seconds after I start the car right after an oil change? I can't imagine it is too good for the engine, even though it only has to go through this once every 3-4000 miles.
bcook_84 is offline
post #2 of 24 (permalink) Old 03-10-2008, 04:35 PM
I don't know of any way unless you primed the oil pump after each oil change or cranked the engine until the oil pressure gauge shows a reading. But I wouldn't worry about it. I never gave it any thought when mine did it.
post #3 of 24 (permalink) Old 03-10-2008, 04:44 PM
rbrown's Avatar
Fill the oil filter with oil before install.
But aside from priming each time like 486 said, no.
rbrown is offline
post #4 of 24 (permalink) Old 03-10-2008, 05:06 PM
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
Pull the ecm fuse and crank it over a couple of times.
Will reset the computer too...
~MG~
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #5 of 24 (permalink) Old 03-10-2008, 05:12 PM
strung's Avatar
i too used to worry about this....priming the oil filter will do.
pimp'n aint easy
mods: air silencer delete w/ k&n panel filter, magnaflow di/do tru duals w/all cats removed, sct 92 oct tune by blue oval chips, tokico advanced handling suspension kit
strung is offline
post #6 of 24 (permalink) Old 03-10-2008, 05:15 PM
MadGoat's Avatar
But trying to install a fluid filled oil filter on a 4.6 in our cars is practicly asking for a shot in the mouth! (of oil that is...)
~MG~
MadGoat's Birds
RIP
MadGoat is offline
post #7 of 24 (permalink) Old 03-10-2008, 05:16 PM
~MG~
I wouldn't recommend the ECM fuse as it will have to relearn its adaptive strategy all over again. The fuel pump fuse would be a better choice IMO if you wanted to crank it.
post #8 of 24 (permalink) Old 03-10-2008, 05:36 PM
MadGoat's Avatar
Agreed.
~MG~
MadGoat's Birds
RIP
MadGoat is offline
post #9 of 24 (permalink) Old 03-10-2008, 06:10 PM
Resident Line Creator
th3subtl3on3's Avatar
Last time I changed the oil, I filled the filter about half way, and it dramatically helped with the knocking upon the first startup.
-Brian
th3subtl3on3 is offline
post #10 of 24 (permalink) Old 03-10-2008, 07:33 PM
Jeremys95Thunderbird's Avatar
~MG~
I couldn't agree more!
1995 LX 4.6 Stock for now.
Jeremys95Thunderbird is offline
post #11 of 24 (permalink) Old 03-10-2008, 08:23 PM
-Rod
post #12 of 24 (permalink) Old 03-10-2008, 09:40 PM Thread Starter
Thank you all for the suggestions. I will try filling the filter with oil first. Thankfully I have it easier than the 4.6 guys, lol. Rod, how much does one of those things cost?
bcook_84 is offline
post #13 of 24 (permalink) Old 03-10-2008, 09:45 PM
I probably have about $300 in my accumulator setup. But considering the $$ in the engine, being able to prime the engine before every fire-up was worth it to me.
-Rod
post #14 of 24 (permalink) Old 03-10-2008, 10:21 PM Thread Starter
Yeah, I don't think a cost-benefit analysis would come out in favor of me getting one of those for a mostly stock engine that just rolled over 128,000 miles, lol.
bcook_84 is offline
post #15 of 24 (permalink) Old 03-11-2008, 12:25 AM Thread Starter
Another quick question. As I mentioned earlier, my engine just rolled over 128,000 miles. I have been reading a lot lately about 5w30 vs. 10w30. I usually run 10w30, but I wonder if I am running too heavy of a weight for the winter (central Indiana). Any suggestions would be helpful. And if I did switch to 5w30, would it be ok for year-round use? I use Pennzoil Platinum with a Motorcraft filter, just for reference.
bcook_84 is offline
post #16 of 24 (permalink) Old 03-11-2008, 12:53 AM
I run 5w30 in the winter and 10w30 in the summer, but that's just me. You could use 5w30 all year though, no problem.
post #17 of 24 (permalink) Old 03-16-2008, 03:05 PM Thread Starter
Thank you all for your input. I pre-filled the filter before putting it back on, and that really helped the knock. Chris, I decided to stick with 10w30 since it is starting to get warmer, and because my engine is getting up there in miles, so internal tolerances within the cylinder bores might not be as tight as before. With 128,750 miles on her, I kinda worry about running a lighter oil.
bcook_84 is offline
post #18 of 24 (permalink) Old 03-16-2008, 04:57 PM
greenmachine's Avatar
Does it really matter if it knocks a few times at first start after a chance? This car above is at 125k, I put 230k on another 4.6 in a Marq, and many others have put many miles on these motors. ALl the cars in the world, never heard this being a issue for any of them. This is one I would not worry about.
Tim
2005 Magnum 5.7 Hemi (93k)
1997 Jaguar XK8 CONV (80k)
1996 Tbird (120k, V8)
"The older I get the smarter I was"
greenmachine is offline
post #19 of 24 (permalink) Old 03-17-2008, 12:24 PM
Banned
Send a message via Yahoo to ThunderRoad
Smile The 5-30 Is The Problem
IT LETS THE BEARUNGS WEAR MUCH SOONER WAS DONE FOR BETTER MILEAGE I USE 15-40 ALSO SOME LUKAS ADDITIVE WILL KEEP THE BEARINGS COATED AS THE HOT OIL WILL DRAIN OFF
ThunderRoad is offline
post #20 of 24 (permalink) Old 03-17-2008, 09:03 PM
what is the knocking you guys speak of? are you talking about the rod bearings? out of all the oil changes ive done i have never heard a motor knock after changing the oil. Ive had gm 3800s, ford 3.8 SC, 5.0s, 4.6s, 5.4s and the list goes on.
Leer5000 is offline
post #21 of 24 (permalink) Old 03-17-2008, 09:23 PM
It's not a rod knock it's just the lifters.
post #22 of 24 (permalink) Old 03-17-2008, 09:24 PM
turdferguson's Avatar
I think they are talking about piston slap on start up. Happens in my car after oil changes too.
turdferguson is offline
post #23 of 24 (permalink) Old 03-18-2008, 12:42 PM
Nativedetroiter's Avatar
I used Lucas Oil Supplement on my Moms Blazer because of a tapping sound that would occur, after using the oil treatment, all noises seized to exist.
Nativedetroiter is offline
post #24 of 24 (permalink) Old 03-29-2008, 07:33 PM
Not sure if it works on the 3.8 but is does on my 4.6. After I change the oil, I push the gas pedal to the floor and turn the starter for approx 10sec. flooring the pedal will not allow the engine to start but it does at least pump oil through the system. No more startup knocks after oil changes.
W.Cup is offline
