fuel pressure - TCCoA Forums
post #1 of 8 (permalink) Old 03-14-2008, 10:16 PM Thread Starter
fuel pressure
Where is the schrader valve located on the fuel rail for checking fuel pressure on a 94-97 LX with 3.8? Not sure exactly the year, but know it's a later model.
Thanks!
NCredSC is offline
post #2 of 8 (permalink) Old 03-14-2008, 11:22 PM
LOLA's Avatar
Passenger side in the front. You can't miss it.
LOLA is offline
post #3 of 8 (permalink) Old 03-15-2008, 01:11 AM Thread Starter
Thanks a lot Lola!! That is what I needed to know.
NCredSC is offline
post #4 of 8 (permalink) Old 03-15-2008, 11:33 AM Thread Starter
Would you know what the stock fuel pressure should be? The car belongs to a neighbor of my son and I'm trying to get them some info on things to check. It starts, but runs really rough.
NCredSC is offline
post #5 of 8 (permalink) Old 03-15-2008, 11:38 AM Thread Starter
He just called and said they checked it and it was 13 psi. and started leaked down as soon as they shut off motor. That doesn't sound good. Maybe the pump or FPR ??? Or maybe the filter is clogged.
NCredSC is offline
post #6 of 8 (permalink) Old 03-15-2008, 12:40 PM Thread Starter
Info from my son about the car........
ok, well, it hums, try to crank and it'll start then die immediately, then won't start at all...until i remove key and try again
NCredSC is offline
post #7 of 8 (permalink) Old 03-15-2008, 01:54 PM
Sounds like a fuel pump.
birds4us is offline
post #8 of 8 (permalink) Old 03-15-2008, 02:22 PM Thread Starter
That's what I thought. I told him to check the filter just in case. I Pm'd you my number and sons number on sccoa.
NCredSC is offline
