Alternator Question - TCCoA Forums
post #1 of 8 (permalink) Old 03-26-2008, 12:18 PM Thread Starter
jco1385's Avatar
Alternator Question
Will a 01-04 3.8l Mustang alt fit my 97 3.8l? the bolts are straight across like mine, and it looks like it will fit, but i need to be sure.
thanks
jco1385 is offline
post #2 of 8 (permalink) Old 03-27-2008, 09:51 AM Thread Starter
jco1385's Avatar
ok, does anyone happen to know the distance from center to center of the bolt holes? is it roughly 7"?
jco1385 is offline
post #3 of 8 (permalink) Old 03-27-2008, 01:59 PM
It may physically fit but as far as I can tell the eletrical connections on the back aren't the same. It's missing the single wire connector and the voltage regulator looks different.
post #4 of 8 (permalink) Old 03-27-2008, 03:07 PM Thread Starter
jco1385's Avatar
well this is an aftermarket unit. it's 200a HO and i can get it for really cheap. can i make it work? surely i can, right?
jco1385 is offline
post #5 of 8 (permalink) Old 03-27-2008, 03:20 PM Thread Starter
jco1385's Avatar
here's a picture of the back of it. kinda dark, but thats what he has posted.
http://www.knocturnalknights.com/alt/DSC02178.JPG
click the link because the picture is huge
jco1385 is offline
post #6 of 8 (permalink) Old 03-27-2008, 06:19 PM
If it fits then sure, you can make it work. You just need to get a wiring diagram for that alternator and make sure the wires and connector are hooked the same way.
post #7 of 8 (permalink) Old 03-28-2008, 10:42 AM Thread Starter
jco1385's Avatar
ok, i got some pics of the plug
and a better pic of the back
if i get the 01-04 mustang plug it should be simple. where can i find that diagram, and my cars diagram?
jco1385 is offline
post #8 of 8 (permalink) Old 03-28-2008, 10:17 PM
SplitPortBird's Avatar
Yes,, it fits... I run the same alternator instead of those large 3G units. The new ones are called 6G alternator and feature better stability and less rotaional weight.
they sell the pigtail connectors online for like 14$ or you can simply snip one off a mustang at a junkyard.
Its a direct fit and direct wire swap.
SplitPortBird is offline
