Clogged cat(s) - TCCoA Forums
post #1 of 11 (permalink) Old 04-07-2008, 04:58 PM Thread Starter
Clogged cat(s)
My car is throwing the code for bank 2 rich, and im getting that ****ty clogged cat smell sometimes and the car is a dog starting off it stumbles, but once it gets going its fine, so im pretty sure my cats clogged, but was wondering if anyone else had any input here, im deffinately cuttin the cats for sure.
MikeRWK is offline
post #2 of 11 (permalink) Old 04-07-2008, 05:16 PM
Broken up cats typically set codes for catalyst efficiency. You can be sometimes make sure by banging on the cats or nearby exhaust and listening for any loose materials. However, clogged cats typically affect the car the most under load, making it feel like it has no power whatsoever. Also, it can cause the car to run much warmer than normal.
What is causing your rich code? Have you investigated that and found what you need to do to fix it?
post #3 of 11 (permalink) Old 04-07-2008, 05:18 PM Thread Starter
I was thinking it was the 02 sensors, but it hasnt thrown any codes for them.Just this bank 2 rich code.
MikeRWK is offline
post #4 of 11 (permalink) Old 04-07-2008, 05:37 PM
How do the plugs look on the driver's side of the motor? Have you cleaned the MAF recently and reset the computer?
post #5 of 11 (permalink) Old 04-07-2008, 05:39 PM Thread Starter
never checked em but i'll pull one, explain where your going with this, i know if is running too rich the plugs will be black.
MikeRWK is offline
post #6 of 11 (permalink) Old 04-07-2008, 05:45 PM
If the plugs indicate that the engine is truly running rich, then the oxygen sensor can be credited as being okay. Otherwise, the oxygen sensor might be suspect. If you haven't cleaned the MAF lately AND reset the computer, A/F calculations might be off, though generally they tend to be in the lean direction, not rich. If you have done anything lately and not reset the computer, it might be using it's old learned strategies which may no longer be valid for the way the car currently runs, thereby possibly triggering false codes. If the car is truly running rich and only on the one side and the oxygen sensor is okay, you need to check the fuel pressure and fuel injectors on that side. Also, make sure that the intake air sensor and coolant temp sensors are providing good readings to the computer.
post #7 of 11 (permalink) Old 04-07-2008, 05:52 PM Thread Starter
theres a new coolant temp sensor and bank 2 is also running rich.
MikeRWK is offline
post #8 of 11 (permalink) Old 04-07-2008, 07:56 PM
maby the mass air flow senser?
always sideways 97 is offline
post #9 of 11 (permalink) Old 04-08-2008, 05:07 AM
twin turbo 281's Avatar
unplug and pull the 02 sensors out to tell if theres a plugged cat. if it idles or revs easier they may be an issue. What kind of plugs are you running also check the gaps. Factory is .52-.56 as i remember but i wouldnt gapp them any more than .35 or .30 for boosted apps. Also are the wires new?
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #10 of 11 (permalink) Old 04-08-2008, 03:37 PM Thread Starter
im guessing factory plugs and wires, the car was bone stock when i got it and still is pretty much.I'll try pulling the maf and seeing how it runs.
MikeRWK is offline
post #11 of 11 (permalink) Old 04-08-2008, 03:43 PM Thread Starter
its the maf, thanks always sideways 97 you saved me a alot of cursing/guessing.looks like i bought 2 new 02 sensors for nothing but oh well nothing like spare parts.
MikeRWK is offline
