Battery Cables? - TCCoA Forums
post #1 of 4 (permalink) Old 04-07-2008, 08:10 PM Thread Starter
winkeytoofly's Avatar
Battery Cables?
Ok my battery cables are old and in bad shape, ive gone to Advanced and Auto Zone they all have the right lenght but all of them dont have the second cable.
Anyone know a website that sells T-Bird Cables?
Also looked into just replacing the heads of the cables but none of them looked to have enough room to fit both of the wires.
winkeytoofly is offline
post #2 of 4 (permalink) Old 04-07-2008, 08:31 PM
when my negative battery cable end was cracking i cut it off and put one of these on it
http://www.partsamerica.com/ProductD...e=1396&PTSet=A
both wires fit perfectly in it. I thought it looked too small but after putting it on it's a perfect fit.
the_doug is offline
post #3 of 4 (permalink) Old 04-07-2008, 08:48 PM Thread Starter
Hmmm well then ill have to go back and pick that up, i thought they looked way to small but Thanks for the info the sooner i replace these the better mine look grayish black!
post #4 of 4 (permalink) Old 04-07-2008, 09:46 PM
missycougar's Avatar
Send a message via AIM to missycougar
I really didn't want to have a connection like that for my main terminal on my Mark VIII so I bought the pre-terminated cable and used it just for the main wire. For the second wire I stripped it and used a side post connection and put it there.
So it is not ideal because I have two ground connections on my battery and you have to have a dual terminal battery to use it. But I think it looks much nicer then the generic universal connection and I think it's a better connection.
"I'd rather push a Ford than drive anything else."
Current Cars: 2008 Taurus X (84k) 1997 Lincoln Town Car (145k) - 1996 Mercury Cougar (260k)
Previous Cars:2003 Mazda 6 (160K) - 1990 Mercury Cougar (168k)- 1977 Lincoln Town Car (141k) 1996 Lincoln Mark VIII (116K) 1997 Lincoln Continental (212k) 2002 Mercury Mountaineer (92k)
missycougar is offline
