Factory parts to modify 3.8 - TCCoA Forums
post #1 of 10 (permalink) Old 04-15-2008, 09:12 PM Thread Starter
Curtscat's Avatar
I have a 91 Cat. Are there parts from other year or model vehicles that will enhance my performance such as heads, throttle bodies or ?.
Curtscat is offline
post #2 of 10 (permalink) Old 04-15-2008, 09:52 PM
Yeah, splitport heads and intake from a 99+ 3.8 mustang. Or just swap the entire splitport motor into your car. Other than that, there really isn't much you can do for a 3.8. If you don't feel like doing that much right now, you could always upgrade your drivetrain and suspension so that later on when you get some more power, you won't be breaking things.
post #3 of 10 (permalink) Old 04-15-2008, 10:33 PM
Bay_Bird93's Avatar
96-97 3.8 exhaust manifolds are an upgrade and will give you a couple extra hp
'97 Lincoln Mark Viii LSC - Stock
'93 Ford Thunderbird - Splitport & M5r2
'64 Chevrolet Impala SS - Stock
Bay_Bird93 is offline
post #4 of 10 (permalink) Old 04-16-2008, 09:09 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
93-95 lightning engine. you said factory.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 10 (permalink) Old 04-16-2008, 10:40 AM
i was thinkin the triton V-10 myself lmao again.. its factory!
stickysilvertbird is offline
post #6 of 10 (permalink) Old 04-16-2008, 03:00 PM
PCD
Confirmed V6 Nut
Curt, you just looking at the go department, or are you looking at the stop and handling departments, too?
PCD is offline
post #7 of 10 (permalink) Old 04-16-2008, 08:03 PM Thread Starter
Curtscat's Avatar
Thanks guys for the input. I'm on a very tight budget and can't afford alot of new stuff, but try to find stuff in salvage yards or something laying around someones garage for little or nothing.I just put in a pair of headers from a 96 stang, and had the exhaust custom built leaving the cats out, using 2 1/4 in pipe and a heartthrob di/do muffler. I figured that the exhaust was the first step to any other mods.
Oh and by the way guys, If I had the $$$ there would be a V8 making my kitty purr. But I don't,so I keep dreaming (At least they can't take that away.)
I've read elswere in this forum about split port stuff, is that the same idea that the SHO's had?Were there many vehicles with that set up?
Curtscat is offline
post #8 of 10 (permalink) Old 04-17-2008, 01:22 AM
get your car tuned if you want to gain the most out of what you have. Also try and find a 3.27 trac lok pumpkin in the junkyard(you would be very lucky to find one and its worth the 80 the yard would charge you) The smaller stuff can add up too, is maintenance handled first. Fix any rotted rubber bushings. Eliminate body flexing, improving your take off. You said youre on a budget so make sure you don't need any suspension work or other worn out parts. Also diff bushing help. Lots of stuff can be done to make your car feel faster without spending big $. I'd say with a better TC and jmodded or transgo kit(or some other good shift kit product, trans go for a 4r70w is a no no, not sure about aode) you'd be happy.
post #9 of 10 (permalink) Old 04-17-2008, 08:21 AM
PCD
Confirmed V6 Nut
Curt,
Late model Windstars with the 3.8, 99+ Mustang V6s, and F-150 4.2L V6s are all splitports. The parts from the Mustangs and F-150s will fit on your block. Depending on how much you do yourself, and what the cost of parts are, will determine how much splitporting will cost you. It will add about 50% MORE HP to your engine.
PCD is offline
post #10 of 10 (permalink) Old 04-17-2008, 02:03 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
You can modify a NON-H.O. 5.0 (302) throttle body to fit the single-port engine. But the intakes should be ported to support such a large TB (60mm)
96-97 factory exhaust manifolds are a "shorty header" design, worth about 5hp.
Mark VIII 8.8 rear differential is worth about 35lbs weight savings. No power increase, but power to weight ratio improves, which does make you faster.
Mark VIII rear lower control arms are made of aluminum and are worth about 10lbs each. Same Power/weight idea.
-Thomas
Thomas is offline
