Dude wat's goin on ??? - TCCoA Forums
post #1 of 7 (permalink) Old 04-16-2008, 07:20 PM Thread Starter
I got a check engine light on and I got the code and I got a p0340 so I change the camshaft position sensor reset it and drove fine until I stop and try it again and the freakin code came back again anything I miss ? help please
pendejitotbird is offline
post #2 of 7 (permalink) Old 04-16-2008, 07:58 PM
96PRLBRD's Avatar
A P0340 refers to the circuit, not the sensor. There's still something wrong. All the info here:
http://www.obd-codes.com/p0340
96PRLBRD is offline
post #3 of 7 (permalink) Old 04-19-2008, 12:23 PM
A circuit problem could be caused by the sensor. The cam sensor is under the coil pack, held on by 2 bolts. Check the wiring and if it's ok, I would replace the sensor. It's cheap.
post #4 of 7 (permalink) Old 04-19-2008, 06:14 PM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
Originally Posted by pendejitotbird View Post
...so I change the camshaft position sensor...
you read too fast
SOLD the 96 in favor of a 97 ABS, TC, Sunroof
OEM E46 Bi-Xenon D3S
XBox 360 gamertag: POPIMP96
fl96thunderbird is offline
post #5 of 7 (permalink) Old 04-19-2008, 06:28 PM
When i had mine replaced, they replaced the synchronizer as well. I was told that it was messed up also. If they would have replaced it the problem would have come back due to the fact that the synchronizer would chew up the new one again. When i got the parts back i noticed that the synchronizer was messed up as well. It looks like a small distributor.
tino is offline
post #6 of 7 (permalink) Old 04-20-2008, 01:24 AM
Originally Posted by fl96thunderbird View Post
you read too fast
You are correct. In that case, I would check the syncrhonizer assembly carefully to make sure all seems well and that there is no physical contact between the rotating hall effect magnet and sensor.
post #7 of 7 (permalink) Old 04-20-2008, 02:06 PM
Blindloser1080's Avatar
yes, I had this exact same problem with mine chewing up cam position sensors. I finally took out the synchronizer, and found out there was a lot of play in it (going side to side, was oval shaped) bought a new one from Ford, replaced it and havent had a problem since.
Blindloser1080 is offline
