Power steering lines!!! - TCCoA Forums
post #1 of 5 (permalink) Old 09-23-2011, 10:47 AM Thread Starter
I am working on my brother's 1994 Thunderbird LX 3.8...replaced the steering pump and gear...i am trying to get the lines hooked back up and have looked through countless searches on here, the factory service manual, it doesn't work...
Any quick suggestions on doing it got to get the car done as it has to be worked on outside currently and weather is slowly getting colder... thanks in advance
steves t-bird is offline
post #2 of 5 (permalink) Old 09-23-2011, 02:13 PM
dDUBb's Avatar
18mm ... i use a crows foot attachment and start it by hand. We're talking about the fitting on the rack and pinion right ?? The swivel is a little tricky, usually I need to remove the swivel just to get the rack in / out of the K-member.
dDUBb is offline
post #3 of 5 (permalink) Old 09-23-2011, 03:58 PM
slick59's Avatar
You need a whole lot of the following:
Time
Patients
Beer
start it by hand and use a crows foot.
I can explain it to you, but I can't understand it for you
Tim
1994 Cougar 3.8L Supercharged
1990 Tbird Supercoupe
slick59 is offline
post #4 of 5 (permalink) Old 09-23-2011, 07:01 PM Thread Starter
you guys do it with the rack bolted in??? cause the factory service says to leave it unbolted to start it...
post #5 of 5 (permalink) Old 09-23-2011, 09:46 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I have done it both ways. I had less hell the times that I didnt take it loose, IIRC. Be sure to replace the white seals on the line nuts.
-Rob
Rob is offline
