Catalytic Converter Meltdown - TCCoA Forums
post #1 of 48 (permalink) Old 11-25-2011, 12:40 AM Thread Starter
Raptor22's Avatar
Just got my converters replaced and exhaust done to find out that the old converters werent just clogged, they had encountered a full thermal meltdown. I was told that this was caused by a rich burning situation where too much unburned fuel was making its way into my cats. What would be causing this situation and what can I do to remedy it so I don't melt my new cats in the future?
I am replacing my spark plugs (with Iridiums), wires, cap and rotor tomorrow, and my thermostat soon to ensure proper operating temperature. When I start the car the fan comes on instantly and I dont think it ever reaches operating temperature. The highest the gauge ever comes upto is halfway between C and normal, usually its just above C. The coolant temperature sensor is functioning properly. Could a cold running situation cause the car to run rich?
There is also a plug that comes off my wiring harness near my coolant temperature sensor that doesnt appear to be plugged into anything, but I dont see anywhere to plug it in. Any ideas on where it goes?
Thanks guys.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 48 (permalink) Old 11-25-2011, 01:08 AM
As seen below, there are two sensors, Engine Coolant Temperature & Water Temperature. One operates gauge and the other goes to ECM:
~Rick
TCCoA Sig
post #3 of 48 (permalink) Old 11-25-2011, 01:35 AM
I'll add that in 1989, the temp sensor used for the gauge was made with a bad crimp, and is known to fail reading-low.
I'd swap that one (the one on the driver's side, with one screw post terminal) before I worried about the indicated temperature much.
RalphP is offline
post #4 of 48 (permalink) Old 11-25-2011, 05:01 AM Thread Starter
Raptor22's Avatar
Oh awesome. Thanks for the information about the temperature sensors, I will compare that picture to what I have under my hood tomorrow.
Any ideas about the rich-burn situation?
Raptor22 is offline
post #5 of 48 (permalink) Old 11-25-2011, 05:54 AM
bowez's Avatar
I had that happen to my Cougar bad ECT.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #6 of 48 (permalink) Old 11-25-2011, 07:20 AM
If not the ECT sensor, new O2 sensors and clean the MAF? Does it have a Check Engine light illuminated?
~Rick
TCCoA Sig
post #7 of 48 (permalink) Old 11-25-2011, 09:36 AM
I don't think the 89s had a MAF sensor, IIRC they were speed-density through 90.
Since you mention the check engine light, it might be worth running the OBD-I self tests. Ground the self-test input on the test plug then start the car to start the process. I can't remember all the details since it's been a while since I've done it, but I think fordfuelinjection.com has the process outlined.
post #8 of 48 (permalink) Old 11-25-2011, 11:41 AM
BlueEyes's Avatar
Glad to see you got the Bird running again. I'm wondering how long I have until one of mine clogs.
-Kelly
Fuelly
BlueEyes is offline
post #9 of 48 (permalink) Old 11-25-2011, 12:01 PM
Yeh, you're right; you can even see the MAP (yes MAP, not MAF) sensor in the picture above! lol
Hey, maybe it needs a new MAP sensor!
~Rick
TCCoA Sig
post #10 of 48 (permalink) Old 11-25-2011, 02:06 PM
Go get your car tuned this should stop it running so rich.
post #11 of 48 (permalink) Old 11-25-2011, 04:09 PM
Yeah, that would cure it from running rich. But it's a band-aid fix at best.
But ask yourself this. With the factory tune, did the car run rich? Doubtful.
Therefore something has failed and is malfunctioning that is causing the car to run rich. What would happen if the problem causing his rich condition got worse after he had it tuned to compensate? The cause of the problem is what should be addressed, not a workaround. Why "fix" the computer when it's not the computer that's failing?
post #12 of 48 (permalink) Old 11-25-2011, 08:09 PM
Ok go get a new set of O2 sensors when you get it tuned LOL
post #13 of 48 (permalink) Old 11-25-2011, 11:09 PM
dDUBb's Avatar
It would be helpful if you could look at the Long term fuel trim, but since its an 89 .. good luck with that.
Your fan shouldnt turn on right away .. depends on the wiring, but some cars you unplug the Coolant temp sensor for the engine ( not the guage ) and the PCM thinks youre either at -40 degrees or 248 .. fan turns on either way as a failsafe. I would figure out why this is happening before changing out plugs and rotor, etc ..
Yes the engine runs Rich when it is cold to get it to warm up faster, if your PCM thinks its cold all the time ....
Need to test those sensors first.
dDUBb is offline
post #14 of 48 (permalink) Old 11-25-2011, 11:42 PM Thread Starter
Raptor22's Avatar
I will replace the coolant temperature sensors tomorrow, and look into O2 sensors. I will also take pictures of the two plugs that are unplugged and see if you guys know where they go. That would cause my fan to turn on if they are unplugged.
Raptor22 is offline
post #15 of 48 (permalink) Old 11-26-2011, 12:47 AM Thread Starter
Raptor22's Avatar
Perhaps, from the mechanic I talked to he told me that a rich/lean situation on an OBD1 Ford is an incredibly difficult problem to diagnose. Basically I have to throw sensors at the problem...
Thanks Kelly, its nice being back in my 'bird.
I will see if they tell me anything, that would make finding a solution to my problem much easier. I've only ever pulled codes with a scanner before, but I dont own one. I'll try the "light blink" method tomorrow.
And one other question, where is the thermostat located on my car?
Raptor22 is offline
post #16 of 48 (permalink) Old 11-26-2011, 06:25 AM
Follow the upper radiator hose to the block; the metal tube that has two bolts with the "bulb" shape under the air bleed bolt (near the gauge sender) is the housing.
post #17 of 48 (permalink) Old 11-26-2011, 01:16 PM Thread Starter
Raptor22's Avatar
Under the orange thing right on top? Awesome.
What temperature should I get?
Raptor22 is offline
post #18 of 48 (permalink) Old 11-26-2011, 02:04 PM
dDUBb's Avatar
Stock one .. probably 195 degrees.
dDUBb is offline
post #19 of 48 (permalink) Old 11-27-2011, 01:46 AM Thread Starter
Raptor22's Avatar
Hey Dan, this is really weird. Why do I have two coolant temperature sensor plugs? One was tucked back behind where the gauge sending unit is and the other was plugged into the old engine temperature sensor but it comes from some random place under the intake manifold. WTF is this?
(yes, I know the gauge sender was unplugged, I plugged it in after taking the pictures.)
Raptor22 is offline
post #20 of 48 (permalink) Old 11-27-2011, 10:14 AM
BlueEyes's Avatar
lol... bizarre... Someone was messing with the wiring. Chase down both wires and see where they go. One looks OEM (89) one looks semi-new. Maybe the PO at one time tried to add a aftermarket temp gauge and was tapping the wrong sensor. Who knows.
-Kelly
Fuelly
BlueEyes is offline
post #21 of 48 (permalink) Old 11-27-2011, 11:40 AM Thread Starter
Raptor22's Avatar
But the PO to my knowledge was a dead old lady original owner...
I think there was some shadetree BS that happened to my wiring. I'm going to have to figure this out. Also, theres a plug undone over by my PS pump:
All the sensors on my washer fluid and PS pump are plugged in... probably another duplicate.
Raptor22 is offline
post #22 of 48 (permalink) Old 11-27-2011, 12:04 PM
Random guess about the plug near the PS pump - might be the EVO plug, not used on N/A 3.8s but on the SCs.
post #23 of 48 (permalink) Old 11-27-2011, 12:26 PM
96PRLBRD's Avatar
The connector by the steering pump is for EVO which you don't have.
--> My most recent pics <--
96PRLBRD is offline
post #24 of 48 (permalink) Old 11-27-2011, 04:06 PM
dDUBb's Avatar
The two sensors for the temp ..
Engine Coolant temp Sensor - this is the 2 wire sensor, Black / White and Light green / Yellow .. this one goes to your EEC, this is VERY important it is plugged in and working correctly.
Water temp sensor - this is the one wire that goes to your gauges, it is not read by the PCM.
dDUBb is offline
post #25 of 48 (permalink) Old 11-27-2011, 04:51 PM
Bay_Bird93's Avatar
If you have the digital temperature control unit (forgot the actual name) where you can control the cabin temperature, then you have actually three coolant temp sensors. The unhooked plug by the power steering is for the EVO, which some 3.8 n/a's did come with. Mine has it.
'97 Lincoln Mark Viii LSC - Stock
'93 Ford Thunderbird - Splitport & M5r2
'64 Chevrolet Impala SS - Stock
Bay_Bird93 is offline
post #26 of 48 (permalink) Old 11-27-2011, 05:19 PM
SATC/EATC both use the CELO (Cold Engine Lock Out) sensor, or switch, which is the THIRD temp sensor.
It's got a different sized head than the gauge sensor does.
RalphP is offline
post #27 of 48 (permalink) Old 11-27-2011, 08:45 PM
dDUBb's Avatar
Yeah .. but that would have NOTHING to do with the catalytic converters melting - its just an On/off switch - to disable the air conditioner. Same with the Temp gauge, it only displays on the dash.
The ONLY coolant sensor that could effect engine performance is the Engine coolant temp sensor.
dDUBb is offline
post #28 of 48 (permalink) Old 11-27-2011, 09:27 PM
True.
The three are completely unrelated to each other.
I apologize if it sounded like I was saying anything else - I was just adding the third sensor on some cars to the list.
For cars with the one-wire gauge sending unit, the one with TWO wires is for the ECU. Later 4.6's (and maybe 3.8's) had a 2-wire unit for the gauge also. Or so I've gathered from the parts lists ...
RalphP is offline
post #29 of 48 (permalink) Old 11-27-2011, 10:16 PM
Faster than Porkchop
cjchevez's Avatar
My fuel pressure regulator was the cause of my cats burning
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #30 of 48 (permalink) Old 11-27-2011, 10:38 PM
Bay_Bird93's Avatar
It was just a FYI type thing for Conner for future reference. I don't think I even used that sensor on my splitport, but then again Conner has my A/C. Definitely should check fuel pressure at the rail like stated above.
