Problems after installing a new throttle position sensor - TCCoA Forums
post #1 of 3 (permalink) Old 12-08-2011, 09:02 AM Thread Starter
I have a 96 tbird with the 3.8 and 167000 miles. I was getting a throttle position sensor code so i purchased a new one and installed it. After start up the car seemed to idle as it should for a few seconds up to a min. Then the revs will climb into the 1500-2000rpm range and make the car extremely hard to operate. I have heard of other people having this issue but havent heard of a solid solution. So before I go any further im hopeing someone on here can help me out as far as where to look first. Thanks!!
bmlawson2003 is offline
post #2 of 3 (permalink) Old 12-08-2011, 07:15 PM
Roadrunnner's Avatar
Uh, hi. You should try introducing yourself first. Its polite thing to do.
Will
Roadrunnner is offline
post #3 of 3 (permalink) Old 12-08-2011, 09:59 PM
Yes, you should introduce yourself.
As for your problem, you need to adjust the TPS. Check the voltage coming from it with the trottle closed. It's supposed to be ~0.98vdc.
When mine was at 1.00-1.05vdc (which doesn't sound like much difference), I had the same issues you're having.
If you don't want to mess with elongating the holes to make some adjustment possible, you can try disconnecting your battery a few minutes to reset the ECM and see if it adjusts to your new TPS without you having to change anything.
~Rick
TCCoA Sig
