3.8 Problems - Please Help - TCCoA Forums
post #1 of 99 (permalink) Old 06-19-2012, 03:06 AM Thread Starter
Raptor22's Avatar
My car develops bad hesitation and shuddering under acceleration after the car warms up, it gets worse and leads to bad idle at stoplights. Most of the engine sensors are new, along with a new fuel filter, and a new exhaust with new cats. Im pulling codes 21 and 74, though cleaning the connection on the ECT sensor made 21 go away. I'm wondering about my fuel pressure, but also about my thermostat. I'm going to change out my thermostat tomorrow because I'm thinking that it might be overheating and causing my fuel mixture to lean out and slightly vapor lock. The other alternative is a fuel pressure regulator, which is why I'm going to check my fuel pressure tomorrow. Any other ideas?
What else could be causing this problem? I am deathly afraid of melting my new cats.
There was a 95 3.8L Taurus wagon that came into my work a while ago that was throwing similar codes and having similar problem, ended up the computer was fried. Could that be a possibility with my car?
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 99 (permalink) Old 06-19-2012, 03:37 AM
dDUBb's Avatar
Check for vacuum leaks.
What makes you think its overheating ?
PCM rarely goes bad, usually bad inputs from the sensors. New sensors dont always work properly. Monitor your A/F on the o2 sensor signal.
Oh yeah .. check for blown Head gasket also, do a compression and leakdown test.
dDUBb is offline
post #3 of 99 (permalink) Old 06-19-2012, 11:54 AM Thread Starter
Raptor22's Avatar
My gauge doesn't work, or actually it barely works (only moves on the very low end of the spectrum) so I can't be totally sure its overheating but it feels hotter than it should be when I open the hood. As far as my sensors I think it might be the wiring going to them causing the issue. How do I know what the A/F mixture is from the o2 sensor signal? What is the range I should be looking for?
Raptor22 is offline
post #4 of 99 (permalink) Old 06-19-2012, 02:27 PM
dDUBb's Avatar
You wont know the AF mixture unless you smog it .. the o2 will tell you if its switching rich to lean but not adaptive fuel trims .. excessively lean or rich will usually trigger the MIL.
Do a continuity check on your wiring.
I doubt vapor lock .. thats oldschool. More likely blown HG.
OBD1 sucks.
dDUBb is offline
post #5 of 99 (permalink) Old 06-19-2012, 02:38 PM Thread Starter
Raptor22's Avatar
OBD1 sucks.
It passed smog with flying colors (like 1s and 2s for the numbers of NO and CO2) like 500 miles ago, I was going to have the O2 sensors replaced but the old ones tested fine and my smog scores was low. Ive been told that diagnosing a lean/rich problem on an OBD1 Ford is one of the most difficult things as a mechanic. You think my head gasket could be blown between cylinders causing the problem? I'm not burning oil or coolant, and I don't have chocolate milkshake in my oil pan or my radiator...
Raptor22 is offline
post #6 of 99 (permalink) Old 06-19-2012, 02:43 PM
dDUBb's Avatar
Your car runs rough .. could be a lot of things. Blown HG, EGR stuck open, vacuum leaks, bad plugs / wires, etc etc ..
Just because it passed smog 500 miles ago doesnt mean its not broken today.
I just fixed a 94 Mark, failed miserably on smog two weeks ago .. replaced the PCM and it passed today no problem.
dDUBb is offline
post #7 of 99 (permalink) Old 06-19-2012, 08:38 PM Thread Starter
Raptor22's Avatar
New plugs, new wires, most engine sensors are new...
It could VERY possibly be the EGR considering the rest of the system got screwed up when my cats fried...
Raptor22 is offline
post #8 of 99 (permalink) Old 06-19-2012, 11:49 PM
dDUBb's Avatar
Unplug the vac line from the EGR and see if it runs any different.
Ive seen new plugs fail within the first couple hundred miles .. just sayin.
dDUBb is offline
post #9 of 99 (permalink) Old 06-20-2012, 12:38 AM
There's a TSB on bad sending units for the gauge temp sender - all 1-wire senders to something like 1996 or so.
I'd swap that sending unit quick.
They're not that much - down to $2.44 at RockAuto. Add in a gallon of 50/50 (ideally, a gallon of concentrate and a gallon of distilled water, make 2 gallons of your own!), a small spool of PTFE tape, and you're good to go.
RalphP is offline
post #10 of 99 (permalink) Old 06-20-2012, 12:44 AM Thread Starter
Raptor22's Avatar
I have another set of new plugs I can throw in there to see if it helps. Wouldn't unplugging the vac line to the EGR cause another vacuum leak?
The sending unit is new as of January, and strangely enough I have a 2 wire sending unit. Its a red and a white wire IIRC.
Raptor22 is offline
post #11 of 99 (permalink) Old 06-20-2012, 01:21 AM
dDUBb's Avatar
Well plug it up with something, obviously.
Like I mentioned before .. new parts dont always mean they work correctly. Check your wiring for continuity first.
dDUBb is offline
post #12 of 99 (permalink) Old 06-20-2012, 01:37 AM Thread Starter
Raptor22's Avatar
Wouldn't the EGR still be open then, I don't really know that much about HOW the EGR works.
How would I test the continuity? Put a multimeter between the connector and the sending unit?
Raptor22 is offline
post #13 of 99 (permalink) Old 06-20-2012, 01:55 AM
dDUBb's Avatar
Let me use my Psychic mechanic ability .. ( grabs a bucket of chicken bones, shake shake shake .. throws them onto the ground .. ) "yes, this does not look good"
You can cap off your egr with a soda can. Stuck open would usually cause it to run rough cold also ..
Test continuity with a multimeter, yes .. unplug both sides of the wireharness.
If it doesnt act up cold, you need to check everything hot while its displaying the symptoms.
dDUBb is offline
post #14 of 99 (permalink) Old 06-20-2012, 02:41 AM Thread Starter
Raptor22's Avatar
Just went out and started it up, it ran rough. It ran the same with the EGR plugged in as it did without the EGR plugged in and the vacuum line blocked, the vacuum line was sucking alot of air. What does that indicate?
Checking my other vacuum lines I couldn't find any immediate vacuum leaks, though I will try again tomorrow when the sun is up.
Raptor22 is offline
post #15 of 99 (permalink) Old 06-20-2012, 08:46 AM
That's the ECM's sending unit.
There's also one for the gauge.
I'm talking about the gauge's sending unit.
RalphP is offline
post #16 of 99 (permalink) Old 06-20-2012, 02:15 PM Thread Starter
Raptor22's Avatar
No, my gauge sending unit has two wires. Let me put up a picture. Both sending units are new.
Raptor22 is offline
post #17 of 99 (permalink) Old 06-20-2012, 05:54 PM Thread Starter
Raptor22's Avatar
Okay guys, just drove my car 100 miles, here's how it went.
Cruising is fine, normal even. Its only on acceleration that the misfire and stumbling occurs. The idle is rougher than normal. Also I'm sure its running really lean because I filled up in Woodland CA and it only burned 2.01 gallons of gas to get to Chico CA (91.1 miles from station to station). That equates to 45.55 MPG which I would normally think was really awesome however its just another indicator of how lean its running.
Raptor22 is offline
post #18 of 99 (permalink) Old 06-20-2012, 06:07 PM
renello79's Avatar
There's always a possibility that the symptoms could be all related you said it running hotter than normal, hesitation when warm and, running lean right? Well a weak fuel pump would cause all of these symptoms, check your fuel pressure at the rail. A fuel pump is definitely a possibility if you are getting all of these symptoms.
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #19 of 99 (permalink) Old 06-20-2012, 06:19 PM
bowez's Avatar
What brand of plugs did you put in?
If you got 40mpg then you have either faulty O2 or MAF. May be time for a fuel filter but on me those usually so signs of horrible mileage.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #20 of 99 (permalink) Old 06-20-2012, 06:24 PM Thread Starter
Raptor22's Avatar
Going to check it tomorrow. I just need to figure out this issue so my car can be somewhat reliable and I don't fry my brand new cats.
I just replaced the fuel filter like 2 days ago. It doesnt have an MAF but the MAP sensor is new. I put in Autolite plugs, going to check the fuel pressure. I was running iridium for a while but i switched them for the Autolite copper plugs.
Raptor22 is offline
post #21 of 99 (permalink) Old 06-20-2012, 08:22 PM
*facepalms*
No, your sending UNIT has one wire. Your wiring harness has TWO.
Not quite the same thing.
But yah, that's the one I meant - the single wire sending unit.
(For the two-wire, check out the Engine Coolant Temperature sending unit, which has two posts in the one connector.)
RalphP is offline
post #22 of 99 (permalink) Old 06-20-2012, 08:52 PM Thread Starter
Raptor22's Avatar
*facepalms*
Oh yeah, duh, okay. I'ma clean the connector on the ECT, my code doesnt show up all the time, just sometimes.
Raptor22 is offline
post #23 of 99 (permalink) Old 06-21-2012, 12:25 AM
dDUBb's Avatar
You havent checked your fuel pressure, or checked o2 sensor signal voltage ..
Usually a "cold" engine will run richer, but yeah not if you dont have enough fuel pressure .. going to test it, or just talk about it ?
dDUBb is offline
post #24 of 99 (permalink) Old 06-21-2012, 12:40 AM Thread Starter
Raptor22's Avatar
Going to do it tomorrow. The auto parts stores back home don't loan tools but the ones here do. My multimeter was up here and so I couldnt test the O2 sensor voltage either. Going to do both tomorrow.
Raptor22 is offline
post #25 of 99 (permalink) Old 06-21-2012, 01:26 AM
dDUBb's Avatar
You cant check o2 sensor voltage with a regular multimeter, it will average the results .. you need a graphing meter or a scope.
dDUBb is offline
post #26 of 99 (permalink) Old 06-21-2012, 12:39 PM Thread Starter
Raptor22's Avatar
So what would the O2 sensor voltage tell me? I'll see if i can get access to a Verus or at least a Solus.
Raptor22 is offline
post #27 of 99 (permalink) Old 06-21-2012, 02:06 PM
dDUBb's Avatar
Your o2 sensor is working correctly and switching rich to lean ..
Your fuel system is not leaning out at higher RPM.
dDUBb is offline
post #28 of 99 (permalink) Old 06-21-2012, 04:57 PM Thread Starter
Raptor22's Avatar
I was actually thinking it was lean all the time, my plugs are tinged white and I'm getting 46mpg, wouldn't that mean my car was starving for fuel? Forgive my ignorance, I really do appreciate the help.
Tried taking my fuel pressure today, the tester was aggravating me. Out of the two testers I tried, the fuel isnt making it from the Ford adapter to the standard GM attachment on the tester unit. I thought the GM female adapter was cross threaded and that was why it was broken but that's not the case. The tester isn't getting any fuel to it when its hooked up....
Raptor22 is offline
post #29 of 99 (permalink) Old 06-21-2012, 05:07 PM
dDUBb's Avatar
If you turn the key to run, the fuel pump should prime the system .. have you tried pressing the button in the middle of the schrader valve with a small screwdriver or something to see if fuel is coming out ? If theres no fuel pressure it wont read on the gauge. Even a weak pump that bleeds back should read some pressure before it drops back down again .. was that hooked up and tested with the engine running I dont think your car would run with 0 fuel pressure. Usually if your o2 sensor is reading very lean it will bump up the fuel trims and add more fuel to the mix, but not if there is no fuel pressure or the regulator is bad.
Lean all the time wouldnt ruin your exhaust .. but may cause engine detonation problems.
dDUBb is offline
post #30 of 99 (permalink) Old 06-21-2012, 05:42 PM Thread Starter
Raptor22's Avatar
Yeah there is very little at the schrader valve and none making it to the tester. The car starts and runs, crappy. I depressurized the system before hooking the tester up, I primed the system KOEO and the gauge doesn't read anything. I hear my fuel pump priming when I turn the key. Upon starting the car the gauge still doesnt read anything and I am 100% positive everything is hooked up tight. Would that indicate a bad fuel pressure regulator?
Raptor22 is offline
