Air compressor does not engage - TCCoA Forums
post #1 of 5 (permalink) Old 07-18-2012, 02:44 PM Thread Starter
opT
opT's Avatar
Send a message via AIM to opT
Hey everyone, I am having an odd problem with my air conditioning. My car sat in storage for about 2 weeks with the A/C working just fine when I had it out, but when I got the car out it would not work. The entire system was replaced about 2 years ago with all new components and worked great up to this point. One thing I did do in order to get the car out was replace the battery. The one I had in there was about 5 years old and finally bit the dust. Could this have something to do with the A/C not working?
opT is offline
post #2 of 5 (permalink) Old 07-18-2012, 03:10 PM
No, replacing the battery shouldn't have anything to do with the A/C suddenly stopping to work. Step one would be to check to see if the compressor clutch is engaging at all when you turn the a/c on.
post #3 of 5 (permalink) Old 07-18-2012, 07:26 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
You probably already checked, but do you have enough refrigerant?
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #4 of 5 (permalink) Old 07-19-2012, 03:25 PM Thread Starter
opT
opT's Avatar
No, it is not engaging at all. I realize that I phrased my question like a total newbie, I can assure you that I am not. My concern was the possibility of popping a fuse, because of the system not being too old.
Maybe I have a low side leak from the car sitting and not using the a/c?
opT is offline
post #5 of 5 (permalink) Old 07-19-2012, 03:49 PM
Quite possibly. Get the pressure checked - if there's any chance the system has a full charge and the problem is electrical, you will see something on the order of at least 80 PSI or so in the system. Otherwise you've got a leak somewhere.
