how do you change spark plugs - TCCoA Forums
post #1 of 13 (permalink) Old 07-24-2012, 08:46 PM Thread Starter
chsplayer's Avatar
i cannot figure out how to get my spark plugs out. seems like no matter if i try from the top or bottom of the engine i cannot get them out. how do i do this since i never have done it on my own before
chsplayer is offline
post #2 of 13 (permalink) Old 07-24-2012, 09:12 PM
Is your car supercharged or normally aspirated?
Hint: If it doesn't say "Supercharged" on the air tubing, it probably ain't.
RalphP is offline
post #3 of 13 (permalink) Old 07-24-2012, 09:24 PM
Tbird1997's Avatar
I think if your trying from the bottom of the engine your doing it wrong.. ...
Pull the rubber plugs out, and get a 5/8's socket and extention.. (I think its 5/8?) Just don't over tighten or cross thread anything. I can't imagine the pain in the a$$ that would be if something went wrong down in there..
-Patrick
Tbird1997 is offline
post #4 of 13 (permalink) Old 07-24-2012, 09:42 PM
SuperThunderbirdLX's Avatar
His car is N/A. and aren't 3.8's in general are supposed to be tough to change spark plugs? Well, tough for spark plug changes.
-Daniel
SuperThunderbirdLX is offline
post #5 of 13 (permalink) Old 07-24-2012, 09:48 PM
SCs are more difficult because of the IC tubes, 3.8 N/As aren't any more difficult than any pushrod motor.
post #6 of 13 (permalink) Old 07-24-2012, 10:26 PM Thread Starter
chsplayer's Avatar
not supercharged
post #7 of 13 (permalink) Old 07-24-2012, 11:49 PM
What problem are you having with them?
They're not that hard to get to on the NA pushrods.
RalphP is offline
post #8 of 13 (permalink) Old 07-25-2012, 01:16 AM
dDUBb's Avatar
I do mine from the bottom .. not as much room on a SC. On the NA they are fairly easy to get to from the top, but you can do it either way. The AC lines get in the way on the passenger side but there should be plenty of room on the drivers.
dDUBb is offline
post #9 of 13 (permalink) Old 07-25-2012, 05:44 AM
Passenger side is tight, helps to have small hands!
Remove the intake tube to give yourself more room.
post #10 of 13 (permalink) Old 07-25-2012, 05:57 AM
I seem to recall it wasn't too difficult... just grab a 5/8" spark plug socket and have some socket extensions handy if necessary. Pull the boots off the plugs, slip the socket over the end of the plug, use an extension to get clearance for a ratchet from the manifolds if necessary, righty-tighty, lefty-loosey etc. etc...
post #11 of 13 (permalink) Old 07-26-2012, 06:42 AM
Might be like my 4.0 ranger... I had to go in through the wheel well to get to them and actually be able to see what I was doing. It's amazing how much easier it was to change plugs and wires on my 5.0 than on my 4.0...
Coleosis is offline
post #12 of 13 (permalink) Old 07-26-2012, 01:14 PM
dDUBb's Avatar
Why didnt I think of that ???? Just go through the wheel well ..
dDUBb is offline
post #13 of 13 (permalink) Old 07-27-2012, 09:03 AM
good luck with that....
