3 Codes - TCCoA Forums
post #1 of 5 (permalink) Old 08-23-2012, 04:24 PM Thread Starter
Bay_Bird93's Avatar
3 Codes
Driving home today my check engine light came on. Did the paperclip test and got three codes. 118- Engine coolant temperature sensor above maximum voltage / 0-40?C indicated. 157- Manifold Air Flow sensor fault, low voltage. 332- Insufficient EGR flow detected. Its really weird I get all these faults at once and I have a splitport swap so I have really no idea where to start.
'97 Lincoln Mark Viii LSC - Stock
'93 Ford Thunderbird - Splitport & M5r2
'64 Chevrolet Impala SS - Stock
Bay_Bird93 is offline
post #2 of 5 (permalink) Old 08-23-2012, 04:33 PM
I would look for a ground problem first since they all popped up at the same time.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #3 of 5 (permalink) Old 08-23-2012, 04:55 PM Thread Starter
Bay_Bird93's Avatar
Took a closer look and found a melted vacuum line running to the EGR. Cleared the codes and Ill recheck tomorrow if any of the codes come back.
post #4 of 5 (permalink) Old 08-23-2012, 05:29 PM
dDUBb's Avatar
Vacuum line could cause the EGR malfunction.
The other two codes .. usually a short would indicate Low voltage on the PCM side, the High voltage would be from an Open circuit.
dDUBb is offline
post #5 of 5 (permalink) Old 08-24-2012, 07:21 PM Thread Starter
Bay_Bird93's Avatar
Drove it around today and none of the codes came back. Ill check again later next week.
