Correct Idle Speed - TCCoA Forums
post #1 of 6 (permalink) Old 10-28-2012, 11:55 AM Thread Starter
Roach's Avatar
Correct Idle Speed
What's the correct Idle speed of a 3.8 stock engine? Somehow I think mine is way off.
2000 Taurus SE "Lady Hearse"
1995 Taurus SHO "Organ Donor"
1996 Thunderbird LX "Jade Phoenix"
Roach is offline
post #2 of 6 (permalink) Old 10-28-2012, 11:57 AM
No images allowed in signatures.
In drive, 600. At operating temperature in park or neutral, 800.
post #3 of 6 (permalink) Old 12-16-2012, 01:20 PM
'93MN12's Avatar
Mine will shake really bad if it gets that low, so mine is set at 1k
1993 Thunderbird LX. 3.8L with Underdrive Pulleys, Ford Racing Limited-Slip Differential, Intake & Dual Exhaust, and I like to run advanced timing
'93MN12 is offline
post #4 of 6 (permalink) Old 12-16-2012, 01:25 PM
Wouldn't it be better to fix the vibration problem rather than running the idle up?
Just saying.
RalphP is offline
post #5 of 6 (permalink) Old 12-16-2012, 01:32 PM
'93MN12's Avatar
Yes, believe me, if I knew what the problem was that causes the rough idle, I would have fixed it haha. Its very confusing, everything that would come to mind when you think running rough has been replaced/fixed, to no avail :/
'93MN12 is offline
post #6 of 6 (permalink) Old 12-16-2012, 03:17 PM
Compression? Cylinder balance? Leakdown test? Cam checked for a worn lobe? New lifters / pushrods / rockers? Heads checked and redone?
Until you've torn the motor down and blueprinted it back together, not everything has been done
RalphP is offline
