new member here... engine rattle noise 3.8 - TCCoA Forums
post #1 of 21 (permalink) Old 12-05-2012, 08:56 PM Thread Starter
It only happens when the car is changing gears under load (wot) 2000-3500 rpm (from 1-2 2-3 etc) and while decelarating. what is the deal?
I've read that it may be a baffle in the intake or some ish?
I'm a new member on this forum.
It's a 1994 Ford Thunderbird 3.8
  • 96 front end conversion
  • 18"rims
  • xenon body kit (94 style kit)
It runs great at idle and all around, exept for that pesky noise. Oil pressure sending unit was bad at one point, replaced it and no issues. I even drove the car Denver, to Chihuahua, MX and back - no issues.
Greaet forum guys!
94lxbird is offline
post #2 of 21 (permalink) Old 12-06-2012, 12:47 AM
renello79's Avatar
Welcome to the club, off hand nothing comes to mind. However I'm certain that someone can point you in the right direction.
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #3 of 21 (permalink) Old 12-06-2012, 01:11 AM Thread Starter
thanks bro i'm sure they can, looking forward on blabbering about t-birds.
94lxbird is offline
post #4 of 21 (permalink) Old 12-06-2012, 06:38 PM Thread Starter
any help?
94lxbird is offline
post #5 of 21 (permalink) Old 12-06-2012, 07:21 PM
What's the maintenance history on the car? Plugs, wires, fuel filter, vacuum lines, MAF sensor etc.?
post #6 of 21 (permalink) Old 12-06-2012, 07:52 PM Thread Starter
Vacum lines are clean, no leaks anywhere, car is well maintained new wires/plugs and oil 2k ago, MAF sensor was cleaned with a electrical cleaner; fuel filter hasn't been replaced.
i even ran a can of Seafoam trough the vacuum hose on the intake. car smoked like hell that was before i changed the plugs.
This noise has been there since i purchased the car. it runs great exept for that annoying noise.
94lxbird is offline
post #7 of 21 (permalink) Old 12-07-2012, 01:08 PM
Crawl underneath it and slap the cat converters around a bit. They are known to rattle.
FordMan77 is offline
post #8 of 21 (permalink) Old 12-07-2012, 02:25 PM
Muffler baffle broke loose?
post #9 of 21 (permalink) Old 12-07-2012, 02:44 PM
dDUBb's Avatar
Sort of hard to say without actually being able to hear the noise or where its coming from, but you said it sounds like its more towards the front of the car than the rear ..
Usually an exhaust rattle like mentioned above.
I had a customer who had me check out his "rattle" and the muffler baffles were completely blown apart with the pieces rattling inside.
If yours is more towards the front it could be the cats .. very unlikely for it to be an internal engine rattle.
dDUBb is offline
post #10 of 21 (permalink) Old 12-08-2012, 02:59 PM Thread Starter
I'm going to look into the catalytic converters.... since it only does it at higher rpm's maybe the cat's start to rattle and it makes this annoying noise.
http://www.youtube.com/watch?v=n5u3d0Vnpx4
This is the EXACT noise my car makes.
94lxbird is offline
post #11 of 21 (permalink) Old 12-08-2012, 04:08 PM
Hope it's not a rod rap!
post #12 of 21 (permalink) Old 12-08-2012, 04:42 PM Thread Starter
i doubt its something major... my brothers 96 cougar did the same noise... we never figured it out either... that car got traded in with like 200k miles or something.
94lxbird is offline
post #13 of 21 (permalink) Old 12-08-2012, 04:59 PM
95LX4.6's Avatar
I don't claim to be an expert on any of these cars, but I do have a bit of mechanical knowledge and that vid sounds like a rod to me. Might even be a wrist pin but sounded more like a rod.
95LX4.6 is offline
post #14 of 21 (permalink) Old 12-08-2012, 05:40 PM
Rayo's Avatar
this is the EXACT noise my car makes.
You might be concerned about driving that car too far if the engine is making that EXACT noise..
That does in fact sound like "rod knock"..
You'll know it's "rod knock" after the rod blows a hole in the side of your engine block, and makes a chocolate milk mess!
I've seen it happen on these 3.8's
1991 Ford Thunderbird Sport
Rayo is offline
post #15 of 21 (permalink) Old 12-08-2012, 05:46 PM
Rod Rap?
~Rick
TCCoA Sig
post #16 of 21 (permalink) Old 12-08-2012, 09:11 PM Thread Starter
i'm going to get a video for you guys.
94lxbird is offline
post #17 of 21 (permalink) Old 12-09-2012, 05:02 AM
Originally Posted by NetKeym View Post
No, not that Rod rap!
post #18 of 21 (permalink) Old 12-09-2012, 03:20 PM Thread Starter
videos are uploading right now. in the first vid, the car didn't make the noise.
in the second video, it started doing it. It doesent matter in my case if the car is Cold or hot. it sometimes happens when the car is started in the morning (cold start) or is driving after it heats up. the noise comes and goes?
i drove it to denver from vegas and back.. no issues exept for that noise
same thing to chihuahua mexico and back... no issues. exept for the noise
94lxbird is offline
post #19 of 21 (permalink) Old 12-09-2012, 04:28 PM Thread Starter
http://www.youtube.com/watch?v=r8Iw3...ature=youtu.be
theres the video. it sounds kind of like marbles in a tin can
94lxbird is offline
post #20 of 21 (permalink) Old 12-09-2012, 06:12 PM
The Cats have probably worn out other than that, since you've got straight pipes in the back that only leaves the resonator. Another cause of vibration is failed motor mounts.
BTW, welcome to TCCoA.
post #21 of 21 (permalink) Old 12-10-2012, 12:58 AM Thread Starter
ill get under the car and tap on the cat. this noise was present when the car had the stock exhaust system on it.
94lxbird is offline
