How screwed am I/stripped head rocker bolts - TCCoA Forums
post #1 of 9 (permalink) Old 02-18-2013, 03:28 PM Thread Starter
89 Cougar, head gasket replacement at 180,000 miles.
I have 2 rocker arm bolts that I rounded the heads off on. I turned the motor over to get them with barely any tension (I could just wiggle the push rods) but these two I couldn't get out.
They are the second and third ones from the back on the passenger side. I barely could get the head off because of how close the head bolt is to the third rocker arm.
I tried the horrible freight bolt extractor, it didn't do anything except remove another layer of metal. I tried pounding on a 3/8 6 and 12 point socket, nothing. I haven't tried heating it up (I have propane torch, maybe some MAPP gas someplace).
Somehow cut off the rocker arms to allow better access to it?
Take it to a machine shop (already taking it in to get the deck checked/surfaced and maybe a valve job and the valve seals replaced) and have them do it?
Junk it and find another unknown one at a junk yard?
EGR tube broke (it has been leaking), DPFE is smoked.
blow it up, stop wasting my time on backup car?
Why I am in there:
Bangster is offline
post #2 of 9 (permalink) Old 02-18-2013, 04:42 PM
bowez's Avatar
I bet it has been apart before and someone used loc-tite on it. Craftsman has a tool for removing rounded headed bolt. Looks like a nut that you hammer on, if it will fit it should help.
Use heat to aid, or weld another nut on it. This is most likely what a shop will do.
I had to get a head for a customer a couple years ago and was ~$150. FYI
If you have the money and want to keep the 3.8 get a set of 96-98 heads and stop the HG issue.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 9 (permalink) Old 02-18-2013, 04:55 PM
That's what I'd do.
I stripped a side bolt on the WAP block I used to have and tried the Craftsman extractors. All it did was mangle the head worse. Though I think it mangled it just enough as I was able to hammer on yet another size smaller socket to get it out.
I repackaged and returned the extractor set to Sears soon after
post #4 of 9 (permalink) Old 02-18-2013, 05:43 PM Thread Starter
It was apart before, by me, and I am sure I didn't use locktite. It was 12 years ago, head gaskets (hahaha). None of the other 10 have locktite on them.
I think my best/cheapest bet is to sawzall the rockers, get a couple new ones (7 bucks a piece), use the blue wrench and some vise grips.
I have rounded off bolts before, not this badly, and not recessed.
Biggest issue with the rounded bolt head extractors is that none of them seem to have a 9mm one. I have an older (3 years?) Craftsman set and it skips 9 (8, 10, 11, 12, 13, 14, 16), as does the Horrible Freight one. The Horrible Freight one looks higher quality than my Craftsman one.
Bangster is offline
post #5 of 9 (permalink) Old 02-18-2013, 06:00 PM
Rayo's Avatar
My tool of choice for stubborn bolts is Mapp Gas..
I don't let them get to the point of being rounded off, but if they are rounded off for some reason..
A lot of times I'll break out the Dremel, and shape the head of the bolt into a size that fits the next smallest socket size..
I know it's just your back-up car, but you might want to clean some of those metal shavings up and or tape off that area while you work on those bolts..
There's always the Gator Grip..lol
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 9 (permalink) Old 02-18-2013, 07:04 PM
nall_one's Avatar
i had this same issue when one of the rockerbolts cross-threaded its way down. didn't feel tight at all till around half way down, then it wouldn't turn anymore. had to chase the hole out and when i put the bolt back in, it took a while to get it threading right, and it went on super tight and started rounding off. i doubt very much it would ever come out again, and that rocker rattled a bit cold from that point on.
glad i don't have to do a head-job on her since she was sold a while back, but if i ever did, i would get myself a set of newer heads and be done with it.
nall_one is offline
post #7 of 9 (permalink) Old 02-18-2013, 07:59 PM
renello79's Avatar
I'd try beating a 8 point socket on and see how that goes with the help of a torch of course.
Can other cylinder heads be used on a sc with no problems?
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #8 of 9 (permalink) Old 02-18-2013, 08:17 PM Thread Starter
The left and right heads are identical, correct?
Bangster is offline
post #9 of 9 (permalink) Old 03-10-2013, 05:14 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Yep, they fit either side.
-Rob
Rob is offline
