MAF sensor interchange - TCCoA Forums
post #1 of 14 (permalink) Old 02-22-2013, 05:47 PM Thread Starter
Curtscat's Avatar
I am rebuilding my engine this winter and doing some performance stuff. Can I use a MAF sensor from a 2002 mustang in my 91 Cougar if I am putting larger injectors and a custom chip in it?
Thanks.
"I am the way, the truth, and the life. No one comes to the Father except through Me." Jesus
Curtscat is offline
post #2 of 14 (permalink) Old 02-22-2013, 08:13 PM
dDUBb's Avatar
Thanks.
Yes if the chip is tuned for the MAF and Injectors.
dDUBb is offline
post #3 of 14 (permalink) Old 02-22-2013, 09:31 PM
Moderator & Teksid Whore
guitar maestro's Avatar
With a custom chip, or even a cookie-cutter tuned chip, absolutely. Programming that stuff in is child's play.
guitar maestro is offline
post #4 of 14 (permalink) Old 02-23-2013, 01:33 AM
S4gunn's Avatar
Why would you use the MAF from a 2002 Mustang?
Even with a windstar splitport intake and upgraded injectors, I'm not maxxing out my stock 95 MAF (my datalogger samples the MAF voltage). If your MAF is old, well, they do wear out so replacing it isn't a half bad idea.
-g
http://goo.gl/csaet4
S4gunn is offline
post #5 of 14 (permalink) Old 02-23-2013, 05:15 AM Thread Starter
Curtscat's Avatar
Thanks guys for the responses. I was also concerned if the connecters were the same.
I can purchase the hole tube ,MAF and K&N filter as an assy.
I just wasn't sure about the mods involved with this set up.
Thanks again.
Curtscat is offline
post #6 of 14 (permalink) Old 02-23-2013, 09:35 AM
-g
According to a well known former ford engineer, the maf used in 2002+ mustang gt's has superior electronics than anything that came before it.
post #7 of 14 (permalink) Old 02-23-2013, 11:49 AM
I got that same GT part number MAF off a 2008 F-150
~Rick
TCCoA Sig
post #8 of 14 (permalink) Old 02-23-2013, 12:56 PM
dDUBb's Avatar
-g
MAF shouldnt wear out - its basically a heated platinum wire and a thermistor that responds to changes in air temperature passing over the two .. not exactly a wearable item.
The 02 GT MAF has a 80mm housing which should support somewhere over 400 RWHP, you would need a lot more air flow than a splitport V6 setup to maximize that 95 70mm MAF, like forced induction or a modified V8 for example. The OP's 91 MAF is pretty small but still wouldnt be maxed out on most NA V6 setup's.
dDUBb is offline
post #9 of 14 (permalink) Old 02-23-2013, 05:36 PM Thread Starter
Curtscat's Avatar
So, would it be worth the effort to put the GT MAF and K&N filter on my engine? I'm thinking that the engine will be producing around 250 HP with the cam, injectors, head work and chip. I already have headers and dual exhaust with larger tubes.
Curt.
Curtscat is offline
post #10 of 14 (permalink) Old 02-23-2013, 06:27 PM Thread Starter
Curtscat's Avatar
Or will the factory MAF,and TB with a K&N flat panel be all I need for the mods I'm doing?
Curtscat is offline
post #11 of 14 (permalink) Old 02-23-2013, 09:21 PM
Only one way to find out. Hook up a vacuum gauge to the manifold and if you see "more" than -1.5psi (3in-Hg), then you have a significant inlet restriction.
post #12 of 14 (permalink) Old 02-23-2013, 11:33 PM
S4gunn's Avatar
I stand corrected, Dan.
However, they do break, don't they? I know the previous owner of my tbird recently replaced his that there's got to be a limit to how many heatcycles that platinum wire can take.
I guess the two concerns are a) whether or not the MAF is a restriction or b) if the MAF cannot meter the level of airflow coming into the engine. You have suggestions on how to figure out both cases. If the deal for your tune comes with reburns/updates, you may want to try things out in two stages. Stage 1: everything you planned. Do the tests and if needed, proceed with Stage 2: the upgraded MAF + reflash.
-g
S4gunn is offline
post #13 of 14 (permalink) Old 02-24-2013, 12:03 AM
dDUBb's Avatar
-g
It would be more likely the electronics inside the MAF sensor fail, than the platinum portion. Catalytic converters are subjected to much higher heat and chemical abuse than the MAF sensor. I couldnt say why the previous owner replaced your MAF .. while my 94 SC has almost 200k miles on the original MAF.
The maximum amount of airflow the MAF needs to be capable of flowing ( with a safety factor of 10%) can be calculated as follows:
1.1 x Horsepower x BSFC x A/F Ratio
The MAF can be a physical restriction by size, or the capability of the electronics. Two equal size MAF housings may not support the same amount of air flow measurement.
dDUBb is offline
post #14 of 14 (permalink) Old 02-24-2013, 08:21 PM Thread Starter
Curtscat's Avatar
Thanks again guys for the feed back.
After spending almost $500 on parts for our other 2 cars, I will be keeping the parts I have now.
Curtscat is offline
