fuel rail repair - TCCoA Forums
post #1 of 4 (permalink) Old 05-04-2013, 09:32 PM Thread Starter
Curtscat's Avatar
fuel rail repair
So I fired up my engine for the first time tonight and had fuel spraying out of the hoses on the fuel rail. Is there any way of repairing these connections?
"I am the way, the truth, and the life. No one comes to the Father except through Me." Jesus
Curtscat is offline
post #2 of 4 (permalink) Old 05-04-2013, 11:45 PM
S4gunn's Avatar
Yes, you can cut off the stock hoses and replace them with J30R9 fuel injector hose. It's sold by the foot at your local auto parts store. Don't go for J30R7 FI hose even if it's cheaper b/c of the PSI rating. It's meant for carburated applications. Also, use multiple hose clamps at each connection just to be safe.
You can test for leaks with the manifold off by turning on the ignition and checking for leaks.
I did something similar when I built my splitport fuel rails.
http://forums.tccoa.com/showthread.php?t=141039
Regards,
-g
http://goo.gl/csaet4
S4gunn is offline
post #3 of 4 (permalink) Old 05-05-2013, 06:42 AM Thread Starter
Curtscat's Avatar
Thanks Gunn, I'll be hitting the parts store after church.
Curtscat is offline
post #4 of 4 (permalink) Old 05-05-2013, 09:39 AM
S4gunn's Avatar
Please pay close attention to how you need to remove the old hose without nicking the barbs underneath. There are two URLs describing the process.
In the unlikely event that you do nick a barb and it leaks, LMK. I should have an extra singleport fuel rails you can just swap over.
Regards,
-g
S4gunn is offline
