Getting colder air to the intake. - TCCoA Forums
post #1 of 21 (permalink) Old 05-20-2013, 08:27 PM Thread Starter
TheAPyfrom's Avatar
How can I Get colder air into my intake? The filter is where the old box was. Ive heard of people putting them down further into the fender, but havent seen any pictures... Anyone have any they'd care to share? Thanks!
And is it worth it to wrap the intake pipe with stuff like header wrap? (Just something I read.)
96 Thunderbird LX
Color: "Champagne"
3.8, Spectre Intake, No mufflers, Heavy foot.
My Daily Driver.
TheAPyfrom is offline
post #2 of 21 (permalink) Old 05-20-2013, 08:47 PM
Don't waste your time or money - you already have a cold air intake. Intakes that stick further down in the fender, well... do a couple searches on hydrolocked motors and you'll see why.
FWIW air intake temps when moving are usually within 2 degrees of the ambient air temps.
post #3 of 21 (permalink) Old 05-20-2013, 11:37 PM
Mgino96tbird46's Avatar
I never hydro locked my motor with a MAC cold air kit. I even drove through water that was at least 6-10 inches deep.
Mgino96tbird46 is offline
post #4 of 21 (permalink) Old 05-21-2013, 01:17 AM
Tbird1997's Avatar
http://forums.tccoa.com/showthread.php?t=139481
Pic at the bottom. it goes down into the fender. Ran it on v6 and v8 bird works nicely...I refuse to spend $120 bucks for the full Intake kit from the throttle body and settled for this instead.
-Patrick
Tbird1997 is offline
post #5 of 21 (permalink) Old 05-21-2013, 06:09 AM
Not saying it means you will, but have you ever read of a hydrolocked motor WITHOUT an aftermarket CAI? To me it seems like everyone who does lock up their engine has one. Plus, have you ever read of QUANTITATIVELY VERIFIED gains acquired with an aftermarket CAIs over the stock CAI setup? As I said, with a stock intake the air temps are already virtually identical to the ambient air temps.
The reality and truth of them is that they ALL pull air in from the fender cavity behind the passenger headlight or near the EVAP canister. Same air.
Save your money and buy a tune from a reputable tuner. Money MUCH more well spent on gains you will actually notice.
post #6 of 21 (permalink) Old 05-21-2013, 08:49 AM
jco1385's Avatar
I would at most pull the silencer and use a K&N.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #7 of 21 (permalink) Old 05-21-2013, 10:34 AM
Oh, I thought you were referring to having an open filter.
Yeah, echoing what he said, the stock set up with removed silencer is the best for cold air. The only reason I don't use it is the fact that my 90mm LMAF doesn't mate with the stock airbox, so I pretty much have to use an open filter. I hate it because it is sucking in hot engine bay air when I launch it off the line.
post #8 of 21 (permalink) Old 05-21-2013, 10:44 AM
Yup, yup - the ONLY reason I am not running the stock air box is because of my MAF. I ditched the MN12 air box setup in favor of the 99-04 GT style so I could run the 80mm MAF sensor 4 years ago (dang, has it been that long? ). The air is coming from the same place the air would come from if it was the stock air box without the air silencer (an inch under the sheet metal lining the fenderwell).
post #9 of 21 (permalink) Old 05-21-2013, 02:28 PM
I'm thinking of either building a heat shield or getting one for my filter.
post #10 of 21 (permalink) Old 05-21-2013, 03:55 PM
bowez's Avatar
IMO its best to run the OEM air box and K&N if you're keeping the car paper if not.
Now if you want more noise ditch the factory air tube.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #11 of 21 (permalink) Old 05-21-2013, 07:45 PM
rmfk13's Avatar
If you want cold air, put some ice cubes under your filter
Rob
rmfk13 is offline
post #12 of 21 (permalink) Old 05-21-2013, 08:16 PM
^^^^ THIS has been done!
We used to fill the filter/intercooler thingy on my buddy's Buick Grand National with ice 20 something years ago! Made a huge difference!
~Rick
TCCoA Sig
post #13 of 21 (permalink) Old 05-21-2013, 09:25 PM
96PRLBRD's Avatar
If you want to get *really* creative, figure a way to duct your Air Conditioning up in front of the air filter LOL
--> My most recent pics <--
96PRLBRD is offline
post #14 of 21 (permalink) Old 05-22-2013, 12:41 AM
Moderator &amp;amp; Teksid Whore
guitar maestro's Avatar
you do know that the 90mm LMAF mates up to a Terminator airbox with the big snorkel, right? If you cut out just a tad of the sheet metal, you can stuff that snorkel downward by reverse mounting it and sealing it up.
I just cut out the plastic on the airbox like so, and cut the locating tabs from the back-plate of the airbox in order to orient it how I wanted it (downward instead of sideways like the mustangs)
Almost 4" in diameter
Ah, the good ol' days when I had the SVO intake on a running car, lol
guitar maestro is offline
post #15 of 21 (permalink) Old 05-22-2013, 12:54 AM
rushtonracing's Avatar
Cool airbox trick. For those who may not know: For plastic modification projects, and fixes "sonic welders" are available. There are some smaller units on the market. They're not cheap tho'. But then we're not cheap.
rushtonracing is offline
post #16 of 21 (permalink) Old 05-22-2013, 01:08 AM
Tbird1997's Avatar
Where did the snorkel come from? When I pulled mine of the mustang it didn't have one.
-Patrick
post #17 of 21 (permalink) Old 05-22-2013, 02:16 AM
All mod motor'd mustangs up until the Terminator had that style snorkel that grabs air from the passenger side fenderwell. The terminator just happened to come with the largest one (at the opening to atmosphere).
Someone must have taken it off your mustang if it was a 96-04 V8 of any variety (except 2000 Cobra R). Look on ebay, they're all over the place, lol.
post #18 of 21 (permalink) Old 05-22-2013, 04:25 PM
tehsilver95lx's Avatar
buy a cai and make a heat shield for it. or.... connect a "Flex-A-Spout" to the oval where you scilencer was and run the tube to you air box/heat sheild,cai's with out heat shields suck... i know get creative! http://www.f150online.com/forums/lig...-intake-2.html (page 1)
Beater lx,current mods: cold air,drilled and slotted rotors,glass pack muffler. Scrapped
Teal terror 94...trans slip and a fram air hog filter!
94 Sc :Cobra R hood,96-97 Front lights,3.73 Trac Lok,1" Raised top,5% OD Blower Pulley,CAI,Removed resonator,Gutted cats,No mufflers. "It roams around in a open loop speed density tune. killing small children and raping helpless mothers at night."
....THAT DOES NOT MATTER!....
tehsilver95lx is offline
post #19 of 21 (permalink) Old 05-22-2013, 04:57 PM
Ye that helps great when you're running a supercharged 5.4 in a lightning. Lol
post #20 of 21 (permalink) Old 05-22-2013, 06:17 PM
well you know,a rubbermaid trash can could work for us too! i personally want to make a lexan air box
post #21 of 21 (permalink) Old 05-23-2013, 12:03 AM
I want a carbon copy of what Trunk Monkey has. His air box is the best.
