Broken lower intake bolt - TCCoA Forums
post #1 of 8 (permalink) Old 06-25-2013, 09:07 PM Thread Starter
I broke a lower intake bolt off below the hole. Can't seem to center punch it to try an easy out. Any suggestions or punt and get a new head?
1996 3.8 Thuderbird
eichenberg is offline
post #2 of 8 (permalink) Old 06-25-2013, 10:03 PM
skinnytick's Avatar
Are the bolts seized and you broke them off when removing or did they break when you torqued them down?
I have used a flat-head screwdriver that has a slightly smaller diameter than the bolt, cut a small notch into the screwdriver's head and then pounded that into the broken bolt with a hammer. It left enough of an indent that I was able to unscrew the broken bolt.
skinnytick is offline
post #3 of 8 (permalink) Old 06-25-2013, 10:10 PM Thread Starter
It broke off when I torqued it down. I will give that a try tomorrow
1996 3.8 Thuderbird
post #4 of 8 (permalink) Old 06-28-2013, 08:11 PM Thread Starter
Well that didn't work. Didn't make a dent in the broken off part. Think I am going to have to pull the head and take it to a machine shop and see if that can do anything for it.
Question. I just put new head gasket and ne head bolts on. The car has not been fired yet, can I re use the gasket and bolts or is it best to get new ones of both.
1996 3.8 Thuderbird
post #5 of 8 (permalink) Old 06-29-2013, 04:39 PM
tbirdowner302's Avatar
Don't pull the head off, if you do your going to have to replace the gasket and the bolts if you used stock torque to yield. Centerpunch that broken bolt and drill through it. Start small and get bigger. Do your best to be dead center in the middle and at the correct angle. Once you get a Decent size hole use an easy-out to extract it. The one time I did what you did, I ended up having to drill the bolt out completely, bought a 8mm x 1.25 helicoil kit from napa to repair the threads. The important thing to know is that aluminum is a pain to tap threads into, so be very careful to not break any tools while working with it. When aluminum gets hot, you break taps easily.
Before I put any engine parts back together I always clean every bolt and chase every thread into my heads. If you don't do that, this is what happens. Good luck my friend.
Chris
mywhite89-screen name on sccoa.com
89 supercoupe 5-speed, 1.7, 427rwhp
95 supercoupe auto, mpx, 310rwhp
tbirdowner302 is offline
post #6 of 8 (permalink) Old 06-29-2013, 05:17 PM
bowez's Avatar
I would suggest left handed drill(s)
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #7 of 8 (permalink) Old 06-30-2013, 09:08 AM
white lincoln's Avatar
Chris
+1
...and use anti-seize compund on all bolt threads before putting them back in (with the exception of ones that need RTV)
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
white lincoln is offline
post #8 of 8 (permalink) Old 06-30-2013, 09:19 AM
I did that on an air pump pulley mount just recently. All three mounting bolts had snapped off, two came out fairly easy but one just would not come out. I used a drill bit to get a hole made and then used easy outs (I broke a few) to finally break it loose and get the bolts out. Keep at it, soak it in PB Blaster, use a propane torch, hammer and punch to loosen the bolt after you drilll an easy out hole in the bolt.
Try this before you give up and remove the head. I think you can do it, just keep at it. You will spend less money in tools than you will time and money to pay someone to remove that pesky bolt.
And use an electric HIGH SPEED drill when drilling. Cordless drills don't have the speed to drill into metal that hard.
Good luck.
