hesitation during take off - TCCoA Forums
post #1 of 9 (permalink) Old 09-06-2013, 10:26 PM Thread Starter
I've put it on the computer and pulled up 14 codes, mostly repeats. Engine miss-fire, camshaft position sensor and O2 sensor.
I thought the camshaft would fix it but it didn't, it only does under load like when i floor it. I do have a broken O2 sensor right after the cat on the passenger side. Before anything else is done I thought I'd ask.
Last edited by Trunk Monkey; 09-08-2013 at 09:37 AM. Reason: Format for easier reading
darrenketcher is offline
post #2 of 9 (permalink) Old 09-07-2013, 02:25 AM
fix that O2 sensor. your messing up your catalytic converter with that unburnt fuel.
what i did is i just replaced all the cheap stuff at once on my old 3.8 thunderbird. i replaced: TPS, Crankshaft sensor, plugs and wires... I dont know what fixed mine, but it was fixed after that LOL
mercury cougar
a few mods
sig has been shortened
94lxbird is offline
post #3 of 9 (permalink) Old 09-07-2013, 07:36 PM
renello79's Avatar
What are all the codes and year make model motor info, I can run it through the computer at work on Monday and I should be able to shed some light on things.
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #4 of 9 (permalink) Old 09-08-2013, 06:34 AM
darrenketcher,
Did you replace the camshaft position sensor or just the camshaft? Are the codes for the camshaft position sensor and O2 sensors?
Maybe you could edit your post with punctuation to make it a little easier to read.
post #5 of 9 (permalink) Old 09-08-2013, 08:27 AM
Originally Posted by darrenketcher View Post
ive put it on the computer and pulls up 14 codes mostly repeats engine miss fire camshaft position sensor and o2 sensor ive thought the camshaft would fix it but i didnt it only dose under load like when i floor it i do have a broken o2 sensor right after the cat on the passenger side i thought id ask before anything else is done that doesnt need to be
It may be useful to utilize proper punctuation and grammar.
To quote something I read the other day:
Proper punctuation and grammar is the difference between
I helped my uncle, Jack, off a horse
and
I helped my uncle jack off a horse
Could you try this sentence as the paragraph it should be, so I could follow it?
RalphP is offline
post #6 of 9 (permalink) Old 09-12-2013, 02:01 PM Thread Starter
im sorry my grammar isnt perfect i replaced the camshaft positing sensor i have mot replaced the o2 sensor
post #7 of 9 (permalink) Old 09-12-2013, 02:34 PM
dDUBb's Avatar
You have a lot of codes. Please post them all so we can get a better understanding of the situation. I would get that Cam sensor taken care of for sure, that could be a big problem. Any o2 sensor after the cat will not affect drivability - its just to verify if the cat is efficient.
dDUBb is offline
post #8 of 9 (permalink) Old 09-18-2013, 08:57 PM
Gabealicious's Avatar
Darren, at least put periods at the ends of your sentences. You responded to the reply about your grammar with precisely the same poor grammar. Seriously, just try periods at the ends of your sentences if nothing else. It will help us understand your problem and offer solutions.
Gabealicious is offline
post #9 of 9 (permalink) Old 09-18-2013, 10:16 PM
To put what Gabealicious said another way,
"Dude! Take a BREATH!"
RalphP is offline
