E85 - TCCoA Forums
post #1 of 8 (permalink) Old 11-02-2013, 11:00 PM Thread Starter
Dumped96bird's Avatar
E85
any one ever convert there 3.8s to run on e85 ive been wanting to convert for a while but don't know where to start any input would be great thanks
07 Civic SI Sedan-Daily
96 Thunderbird-Project
65 Mustang coupe-Project/Garage Art
http://www.1320addiction.com
Dumped96bird is offline
post #2 of 8 (permalink) Old 11-02-2013, 11:13 PM
Mgino96tbird46's Avatar
It's doable. You'll need a better fuel pump, bigger injectors, and a tune. To see any noticeable gains, you'll want more compression. You'll gain maybe 11% of your current horsepower. You'll burn about 20% more fuel as compared to gasoline. At 9.2:1 compression, I did notice a difference, but not much. Keep in mind, this is with two extra cylinders. lol Now that I have 11.2:1 compression, the difference between E85 and E10 is more pronounced, especially at lower RPM. It feels more torquey.
Mgino96tbird46 is offline
post #3 of 8 (permalink) Old 11-02-2013, 11:41 PM
Earl's Avatar
My coyote f150 is e85/flex fuel ready, I just noticed the new station down the road has it...considering trying it
Earl is offline
post #4 of 8 (permalink) Old 11-02-2013, 11:46 PM
Don't expect much of a difference unless you get tuned to take full advantage of the extra anti-knock capabilities.
post #5 of 8 (permalink) Old 11-02-2013, 11:58 PM
Earl's Avatar
I'm thinking definately no tunes, ford is getting very serious about that stuff, back to stock or not, these days, a tune is an instantly voided warranty, no thanks...truck has plenty of power, stock is nice.
Earl is offline
post #6 of 8 (permalink) Old 11-03-2013, 01:32 AM
rbohm's Avatar
Mgino96tbird46 makes some good observations. in addition though to more compression, you also need a better timing curve as well. one more thing, if oyu convert to E85, i suggest wiring in the ford flex fuel sensor to your system, and adjust your tune accordingly. i would also suggest pushing your compression ratio to no more than 10.5:1 so you can still use the lighter fluid we currently call gasoline. and yes there is a madness to my method, unless you are going to stay with in range of a station that carries E85, you may need to switch back to E10, so you should have that capability should yo decide to go on a long trip. just my opinion.
my mind is aglow with whirling transient nodes of thought careening through s comic vapor of invention.
rbohm is offline
post #7 of 8 (permalink) Old 11-03-2013, 07:41 AM
That's pretty much what I do, sans the flex fuel sensor. Even at 11.2:1, I can still use E10, it just doesn't run as good as it would on E85 due to a less agressive timing schedule.
post #8 of 8 (permalink) Old 11-03-2013, 08:16 AM
rbohm's Avatar
its not a bad way to go, i just tend to prefer everything work as seamlessly as possible, preferably to the point where no one can tell what fuel i have in the tank. but what ever works for you is the best way to go.
rbohm is offline
