Valve Cover Options for V6? - TCCoA Forums
post #1 of 9 (permalink) Old 01-02-2014, 05:24 AM Thread Starter
'93MN12's Avatar
Question Valve Cover Options for V6?
I'd like to improve upon the underhood appearance of my 1993 LX, but it seems as though the aftermarket valve covers are mainly made for the 4.6 crowd or other V8's such as the 5.0, so does anyone have suggestions for a vendor? Preferably some sort of blue or dark gray/black. Nothing too shiny, thanks
1993 Thunderbird LX. 3.8L with Underdrive Pulleys, Ford Racing Limited-Slip Differential, Intake & Dual Exhaust, and I like to run advanced timing
'93MN12 is offline
post #2 of 9 (permalink) Old 01-02-2014, 07:08 AM
There isn't going to be much out there for the 3.8. Your best bet is to just clean up a set of stock valve covers and get them powdercoated whatever color you want.
post #3 of 9 (permalink) Old 01-02-2014, 07:25 AM
I would like to have some valve covers for the 3.8 that don't break so easy. I have replaced mine 3 times, and 90% of them in the junk yard are broken as well. Not sure what material they are make of, but paste seems to be the binder.
BBK makes some 300+ dollar cast aluminum/chrome ones, but most of the aftermarket steel/chrome ones are for CFI and not configured correctly to work with the EFI engines.
Bangster is offline
post #4 of 9 (permalink) Old 01-02-2014, 10:20 AM
Look for a set of valve covers off a 93 SC. That year only the valve covers were made of steel.
post #5 of 9 (permalink) Old 01-04-2014, 01:19 AM
dDUBb's Avatar
Magnesium.
dDUBb is offline
post #6 of 9 (permalink) Old 01-04-2014, 01:52 AM
If you can find them.....
post #7 of 9 (permalink) Old 01-04-2014, 06:59 AM
jhiland32's Avatar
I stripped mine and painted with aluminium and clearcoat, detailed the rest and added some Taylor wires.
Jason H.
Mods:
Last edited by Rodeo Joe; 08-15-2017 at 08:16 PM. Reason: Fixed pictures, PITA Photobucket!
jhiland32 is offline
post #8 of 9 (permalink) Old 01-05-2014, 10:10 PM
I like that.....great job looks fantastic to bad the upper intake has to come off or I would do mine(pulled my upper intake when I first got my car and one bolt is ready to strip out )
transtech520 is offline
post #9 of 9 (permalink) Old 01-06-2014, 08:15 PM
found
neverfastenough is offline
