JLT oil separator installed! - TCCoA Forums
post #1 of 32 (permalink) Old 02-01-2014, 06:04 PM Thread Starter
I took advantage of the decent weather today and installed the oil separator I bought from Rob. Once I figured out where to mount it, it went pretty easy. The 3.8L's PCV is on the passenger side and things are a little crowded on that side of engine compartment.
Found a nice little indent under the cowl!
Drilled the holes for the mounting bracket.
Separator mounted!
Hoses all tied in!
Hose on left of separator goes to the intake.
Hose on right of separator goes to the new PCV valve!
FYI 3.8ers, if you decide to buy one get the 3/8ths hose. Thanks to Rob for giving me a great deal on this, and to Darren for bringing these to my attention!
post #2 of 32 (permalink) Old 02-01-2014, 06:23 PM
Nice looking Joe . And nice craftsmanship on them as well
post #3 of 32 (permalink) Old 02-02-2014, 01:14 AM
Just wait til you see how much oil you collect in there. It's a worthwhile mod.
post #4 of 32 (permalink) Old 02-02-2014, 06:41 AM
Mine here stays dry as a bone after the rebuild.
post #5 of 32 (permalink) Old 02-02-2014, 12:12 PM
dDUBb's Avatar
Looks very nice. I need one of these for each of my Super Coupes, they tend to vaporize the oil in the supercharger and when it condenses in the intercooler I end up with a little bit of oil every time I remove the lower IC tubes. Although this is completely normal, and I believe the oil has a quenching effect .. id still like to put one in-line from the PCV. ( If I could get it to re-route back to the oil pan that would be even better )
Mind if we ask how much this modification cost ?
- Dan
dDUBb is offline
post #6 of 32 (permalink) Old 02-02-2014, 01:01 PM
Rayo's Avatar
Lookin Good Joe..
That matches your engine bay nicely..The fact is serves a purpose makes it even better..lol
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 32 (permalink) Old 02-02-2014, 01:06 PM Thread Starter
Not at all! $115 shipped from RobertP. Then it was like $12 for me to go buy a new PCV, I figured I may as well do that while I was there!
Originally Posted by Rayo View Post
Lookin Good Joe..
Thanks Ray! See what a little money from Christmas time will buy you!
post #8 of 32 (permalink) Old 02-03-2014, 12:16 PM
Overkill Fetish Freak
Good job Joe. I plan to add one to my Focus ST since DI motors love oil suck. I will also add one to the Cougar as well... because roots
-Scott
Dr. FrankenCougie is offline
post #9 of 32 (permalink) Old 02-03-2014, 02:46 PM
nice....I just run mine to my headers!
post #10 of 32 (permalink) Old 02-03-2014, 07:32 PM
I need one of these for each of my Super Coupes, they tend to vaporize the oil in the supercharger and when it condenses in the intercooler I end up with a little bit of oil every time I remove the lower IC tubes. Although this is completely normal, and I believe the oil has a quenching effect..
Not sure what you mean by "quenching"....but if enough oil makes it to the combustion chamber it's No Octane City and that's one of the Power-Added engine's worst enemies.
Delete my account.
94 Thunderbird XX is offline
post #11 of 32 (permalink) Old 02-07-2014, 07:23 PM
ricklovin93's Avatar
Whats the purpose of an oil separator?
"A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed"
ricklovin93 is offline
post #12 of 32 (permalink) Old 02-08-2014, 12:42 AM
An oil separator, or coalescing oil filter, is used in a CCV system to remove oil from the air drawn into the intake tract from the crankcase.
post #13 of 32 (permalink) Old 02-08-2014, 10:01 AM
S4gunn's Avatar
I remember DIY building one for my old 4cyl Honda commuter car a few years ago.
You don't need fancy SS hoses -- you can make this out of the bulk fuel line hose sold at Autozone, a few barbed connectors, and an air/water separator sold at most hardware stores for use with air compressors (you don't want water going into your air tools).
I think my small setup cost $30. You can probably build this bigger one below w/o the fancy connectors for $40.
http://www.svtperformance.com/forums...-write-up.html
Regards,
-g
PS. IIRC, my Honda (used daily for commuting), would collect about ~1oz of oil every month.
http://goo.gl/csaet4
S4gunn is offline
post #14 of 32 (permalink) Old 02-09-2014, 09:36 AM
The difference is this looks much nicer, I'd be happy to put together a group buy or what ever if any u guys are interested
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
All made possible with Braincoating's ported manifolds
RobertP is offline
post #15 of 32 (permalink) Old 02-09-2014, 02:40 PM
Anyone with questions on Oil Separators - I found a good article here on oil control:
http://www.enginelabs.com/engine-tec...d-air-control/
~Rick
TCCoA Sig
post #16 of 32 (permalink) Old 02-09-2014, 03:42 PM
96dirtybird's Avatar
Total "noob" question, is this a good idea for a stock engine? If so, definitely interested if we end up with a group purchase as mentioned by Robert P.
Thanks all.
96dirtybird is offline
post #17 of 32 (permalink) Old 02-09-2014, 03:48 PM
I don't think it's a bad idea, but if there's minimal blowby on a stock motor, it's not as big a deal as on, say, a supercharged/turbocharged engine where there's a lot more blowby due to the higher pressures.
RalphP is offline
post #18 of 32 (permalink) Old 02-09-2014, 05:12 PM
+1 You should have seen the blow-by coming out the exhausts of the power-added engines at the dyno the day I went!
~Rick
TCCoA Sig
post #19 of 32 (permalink) Old 02-09-2014, 05:35 PM
Mod motors suck oil with or without boost, it certainly won't hurt
post #20 of 32 (permalink) Old 02-09-2014, 05:39 PM Thread Starter
If and when the decent weather gets here I'll be watching it.
post #21 of 32 (permalink) Old 02-09-2014, 11:48 PM
Cool, thank u.
post #22 of 32 (permalink) Old 02-10-2014, 12:18 AM
Dude, ALL OHC motors suck more oil than cam-in-block, which do more than flatheads.
It's because more of the oil has to be up there, so there's more oil to drip down around the valve guides, even with as tight a tolerance as we can make.
RalphP is offline
post #23 of 32 (permalink) Old 05-17-2014, 07:19 PM Thread Starter
Took a look at it today when I was cleaning the car up, I got this with 118.8 miles after the install!
post #24 of 32 (permalink) Old 05-18-2014, 07:35 AM
It done its job Joe
post #25 of 32 (permalink) Old 05-18-2014, 07:44 AM Thread Starter
Originally Posted by ThunderChecken View Post
It done its job Joe
I see that!
It amazed me that much was there with so little driving. I think I'll be watching more now.
post #26 of 32 (permalink) Old 05-18-2014, 10:59 AM
The Great Obucina's Avatar
I'm going to put this on my Ecoboost...well, from another company as I'm not a fan of Jay Tucker.
UPR has one also.
"Booyah". Stu Scott.
The Great Obucina is offline
post #27 of 32 (permalink) Old 05-18-2014, 01:25 PM
Obuciina I can give a killer deal if u wanted a jlt make it worth your while
10.75 @128.38
RobertP is offline
post #28 of 32 (permalink) Old 05-18-2014, 02:44 PM
Originally Posted by The Great Obucina View Post
UPR has one also.
Yep, I run one from them on my XR7.
post #29 of 32 (permalink) Old 05-18-2014, 07:38 PM
It's on the short list of things to get. I'll be in touch in a few weeks
post #30 of 32 (permalink) Old 06-08-2015, 04:08 PM Thread Starter
Took a look earlier this afternoon after the trip to Carlisle, a little over 800 miles!
