How to Replace Motor Mounts? - TCCoA Forums
post #1 of 5 (permalink) Old 02-12-2014, 11:03 AM Thread Starter
'93MN12's Avatar
Question How to Replace Motor Mounts?
The title says it all. I have tools, a floor jack, and jackstands, but not sure how im going to get my hands to that tight space. I'm guessing I'll need to remove the headers, but correct me if I'm wrong.
1993 Thunderbird LX. 3.8L with Underdrive Pulleys, Ford Racing Limited-Slip Differential, Intake & Dual Exhaust, and I like to run advanced timing
'93MN12 is offline
post #2 of 5 (permalink) Old 02-12-2014, 12:52 PM
The factory exhaust manifolds, or after market headers?
If the former, you CAN work them out and in.
If the latter ... who knows? But I bet yes, you'll have to pull the headers.
RalphP is offline
post #3 of 5 (permalink) Old 02-12-2014, 01:37 PM
jco1385's Avatar
I have done this before without removing the exhaust. It's been some years now... but if I recall, I put a floor jack with a 2x4 spanning the oil pan. Lift the jack until it just gets the weight. Pull the long bolts that hold the mounts to the k-member, as well as the bolts to the block. Lift the jack up as high as possible. You will need to watch the back of the intake to cowl panel, and the trans to tunnel clearances to not break anything. After that, it's just figuring out a way to get them out of the hole. It can be done.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #4 of 5 (permalink) Old 02-12-2014, 01:38 PM
S4gunn's Avatar
Thats what I remember doing as well. You had to lift the engine without punching a hole in the oil pan.
-g
http://goo.gl/csaet4
S4gunn is offline
post #5 of 5 (permalink) Old 02-12-2014, 02:28 PM
Rayo's Avatar
Engine Support Fixture
An "Engine Support Fixture" is another option..IIRC that's what they use in the Service Department at the dealership..
Here's a 3 bar set-up like what's shown in that pic-->>3 Bar Engine Support Fixture
I could think of a lot of uses for one of these..
1991 Ford Thunderbird Sport
Rayo is offline
