Shaking At Idle 3.8l N/A - TCCoA Forums
post #1 of 9 (permalink) Old 04-16-2014, 06:03 PM Thread Starter
Post Shaking At Idle 3.8l N/A
My 1996 3.8l shakes when in idle in drive.
It doesn't shake when in park or driving just when I come to a stop and the RPMS are low.
What could this be ?
Car shakes so back when trying to park it sometimes dies
Edub400 is offline
post #2 of 9 (permalink) Old 04-16-2014, 10:39 PM
Last tune up? How old are the plug wires? Have you checked for vacuum leaks? How about the IAC valve? Any codes tossed?
Fuelly
RalphP is offline
post #3 of 9 (permalink) Old 04-17-2014, 08:53 AM Thread Starter
Havent had a tune up since i brought it.. (I Know sad =|)
So i much need to change the spark plug && wires.
One of vacuum holes was bad i replaced it.
No codes.
Edub400 is offline
post #4 of 9 (permalink) Old 04-17-2014, 09:02 AM
If all the electronics under the hood are original, pretty much everything is suspect. Vacuum leaks, plugs/wires, TPS, IAC, MAF...
post #5 of 9 (permalink) Old 05-04-2014, 09:03 AM Thread Starter
https://www.youtube.com/watch?v=SvlZ04_2wss
Edub400 is offline
post #6 of 9 (permalink) Old 05-04-2014, 09:36 AM
Is it me or does something in that front end sounds sick?
post #7 of 9 (permalink) Old 05-04-2014, 10:59 AM
S4gunn's Avatar
PS. Nevermind.... bad mounts would never cause the engine to die.
http://goo.gl/csaet4
S4gunn is offline
post #8 of 9 (permalink) Old 05-05-2014, 11:36 AM Thread Starter
lol yea need to replace lower control arm.
Edub400 is offline
post #9 of 9 (permalink) Old 05-05-2014, 11:37 AM Thread Starter
motor mounts are good, and power streeing pump was just replaced.
Edub400 is offline
