sensors controlling timing advance - TCCoA Forums
post #1 of 7 (permalink) Old 05-06-2014, 08:50 PM Thread Starter
Curtscat's Avatar
I have a 91 3.8 and the computer is not advancing my distributor. Does anyone know what sensors I could be checking out? When I built the engine I noticed that it didnt have a knock sensor.
Thanks.
Curt.
"I am the way, the truth, and the life. No one comes to the Father except through Me." Jesus
Curtscat is offline
post #2 of 7 (permalink) Old 05-06-2014, 10:13 PM
I'd first check to see if the SPOUT plug is in, since its whole purpose is to tell the ECU "Hey, don't do any advance, we're working on the timing!"
Fuelly
RalphP is offline
post #3 of 7 (permalink) Old 05-07-2014, 04:55 PM Thread Starter
Curtscat's Avatar
That's fine. I've replaced the pick up in the distributor, the control module, and I have a different computer with a chip. The problem is still there. That's why I'm thinking there is a bad sensor, or something not allowing the signals to get back to the computer.
Thanks.
Curt
Curtscat is offline
post #4 of 7 (permalink) Old 05-07-2014, 08:31 PM
If you eliminate the chip, does it advance?
post #5 of 7 (permalink) Old 05-07-2014, 08:44 PM Thread Starter
Curtscat's Avatar
No. It did it with the old computer too.
Curtscat is offline
post #6 of 7 (permalink) Old 05-08-2014, 09:55 AM
Have you checked the wiring for the SPOUT connector, all the way back to the ECM? An open there will cause the ECU to see the SPOUT plug removed, thereby forcing fixed timing.
Fuelly
RalphP is offline
post #7 of 7 (permalink) Old 05-08-2014, 07:39 PM Thread Starter
Curtscat's Avatar
After you mentioned the spout I started thinking that that would be a good place to start.
I'll start there.
Curt.
Curtscat is offline
