Exhaust Gas Recirculation Tube Pipe 3.8L - TCCoA Forums
post #1 of 8 (permalink) Old 06-26-2014, 08:42 AM Thread Starter
Hello, I am looking for a (EGR Pipe) Exhaust Gas Recirculation Tube Pipe for a 1996 T-Bird i can't seem to find anywhere are they the same for any other Ford or where can i find this part ?
Edub400 is offline
post #2 of 8 (permalink) Old 06-26-2014, 09:59 AM
Rayo's Avatar
This really should be in the Wanted section..
Anyways..To answer your question..
The EGR tube used on the 96-97 Thunderbird/Cougar 3.8L is exclusive to these 2 years..
The previous years used a different tube..There is no other car I'm aware of that uses this unique tube..
I'm afraid this tube has been obsolete for a longggg time, and there's no NOS available..
Your only hope is to find a nice used one..Unfortunately this is the kind of item that frequently breaks, or cracks with time..
So your chances of finding a nice used one are kind of slim..
If you have both ends of your old one..Find someone who can weld, and perhaps they can make you one..
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 8 (permalink) Old 06-26-2014, 10:35 AM Thread Starter
Thanks for reply... So not even the 1996 Ford Mustang 3.8l Pipe will work? Bummer guess will have to find someone who weld then..
Edub400 is offline
post #4 of 8 (permalink) Old 06-26-2014, 10:57 AM
Rayo's Avatar
No..
Rayo is offline
post #5 of 8 (permalink) Old 06-26-2014, 11:48 AM
jco1385's Avatar
I just cut one of these off to delete the EGR on my build.
I didn't want to fight the rusty nut off. I have the tube, cut flush with the nut at the manifold if somehow that will help you. If I remember correctly, the 94-95 tube has one vac (?) line coming off of it, where the later ones have 2. I put 97 manifolds in my 94 and just plugged the 2nd one off.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #6 of 8 (permalink) Old 06-26-2014, 05:59 PM Thread Starter
Update.....They guy said the tube is to thin to Weld.
Edub400 is offline
post #7 of 8 (permalink) Old 06-26-2014, 07:17 PM Thread Starter
No..
Rayo. Will using a high temp green hose work, Sorry for so many questions.
I guy on youtube had used a high temp green hose and said it will work fine.
Edub400 is offline
post #8 of 8 (permalink) Old 06-26-2014, 07:52 PM
Rayo's Avatar
Will using a high temp green hose work?
I'm sure someone else has ran into this issue..Either try doing a search of the forum, or wait for someone else to chime in with a solution..
Rayo is offline
