EGR workaround - TCCoA Forums
post #1 of 15 (permalink) Old 06-30-2014, 12:57 PM Thread Starter
Exclamation EGR workaround
Hello, if someone could please help me out with a workaround for this
my "EGR Valve to Exhaust Manifold Tube" is cut and there seem to be nothing
I could do it get this fix or find the part.
Any information or experience with this is helpful. I took it to a place to try welding it and they said it to thin to weld. I cannot Delete the EGR because I still have to go through inspection. Just my luck the 6 junk yard i have been to don't have any V6 Thunderbird's. Most don't have any Thunderbird's at all.
How can ford stop selling an Emissions part for a car that's not historic.....
Ford Part #: F6SZ9D477B
(EGR Valve to Exhaust Manifold Tube)
Please reply with anywhere you know with this part in stock.
Edub400 is offline
post #2 of 15 (permalink) Old 06-30-2014, 01:52 PM
jco1385's Avatar
You can also look for 96-97 v6 Cougars. I can probably pull one here local, but I wouldn't want to mess with trying to free the tube from the manifold. It would have to ride as an assembly, and that may be costly.
You may also try www.car-part.com.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #3 of 15 (permalink) Old 06-30-2014, 02:14 PM Thread Starter
Thanks for reply i have been calling and looking for hours. I am willing to pay for the part. if you can find someone if local with it.
Edub400 is offline
post #4 of 15 (permalink) Old 06-30-2014, 02:20 PM Thread Starter
Whats the Different between the 1996 Ford Mustang 3.8 ?
Edub400 is offline
post #5 of 15 (permalink) Old 06-30-2014, 02:40 PM
jco1385's Avatar
Someone should be in touch with you shortly. They got this engine to go in a mustang, and they have the part you need. I linked this to him on Facebook.
Hope you get it worked out!
jco1385 is offline
post #6 of 15 (permalink) Old 06-30-2014, 02:43 PM Thread Starter
Edub400 is offline
post #7 of 15 (permalink) Old 07-03-2014, 04:38 PM Thread Starter
Guess im going to have to sell the car all over this part.
Edub400 is offline
post #8 of 15 (permalink) Old 07-04-2014, 09:04 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
I have done quite a few motor swaps and making custom egr tubes is part of the deal. They can be welded, very carefully and it's not very pretty usually. If you take the car to a shop to get it fixed, I'm sure they would get you fixed up. If you can't find any of these tubes in the junk yards, you aren't looking/ haven't considered other vehicles that may fit (94-98 Mustsng v6)
-Rob
Rob is offline
post #9 of 15 (permalink) Old 07-04-2014, 09:46 AM
Check the Mustang V6 sites, V6 Power.net and V6 Mustang Forums. You should be able to find one.
post #10 of 15 (permalink) Old 07-04-2014, 01:34 PM
Rayo's Avatar
If he changed his exhaust manifolds to that of the Mustang..I don't see a problem using the Mustang EGR Pipe..
Of course..That's a lot of work for an EGR Pipe..
Carry on..
1991 Ford Thunderbird Sport
Rayo is offline
post #11 of 15 (permalink) Old 07-04-2014, 01:44 PM
As far as I know, the EGR tubes are the same for both cars. Maybe you can check the part numbers for the T-Bird and the Mustang and see if they are the same!
Carry on!
post #12 of 15 (permalink) Old 07-04-2014, 02:09 PM
Rayo's Avatar
They are not the same Joe..
I have looked up both cars, and each of them have a different part number for their EGR Pipes..If I recall correctly..They use different exhaust manifolds as well..
So yeah..Carry on..
Rayo is offline
post #13 of 15 (permalink) Old 07-05-2014, 10:48 AM Thread Starter
I have took the tube to a few Weld Shop and most say the tube is very small and risk more damage
Edub400 is offline
post #14 of 15 (permalink) Old 07-05-2014, 11:11 AM
ClintD's Avatar
for my 5.0 89 cougar, 5.0 75 Maverick and 4.6 94 Thunderbird I have made custom EGR tubes.
I usually use 5.0 Explorer EGR tubes for donor parts because they are so long and have a nice straight section with the DPFE tubes in it
The Maverick has a 94 Mustang engine with a Explorer intake and headman headers, had to make a complete EGR system for it.
no leaks on any system and the oldest one is 5 years old.
It's not really easy to weld the tube, but if your careful and control the heat it can be done.
ClintD is offline
post #15 of 15 (permalink) Old 07-07-2014, 08:21 AM
jco1385's Avatar
Sorry about the delay. The guy has signed up here, but can not PM you. Are you on facebook, or can you PM me a way to have him contact you?
jco1385 is offline
