Knock sensor - TCCoA Forums
post #1 of 14 (permalink) Old 07-15-2014, 05:55 PM Thread Starter
Curtscat's Avatar
Knock sensor
Where is the knock sensor located on my 91 3.8?
"I am the way, the truth, and the life. No one comes to the Father except through Me." Jesus
Curtscat is offline
post #2 of 14 (permalink) Old 07-15-2014, 06:08 PM
You don't have one. The only MN12s that had one were the SCs.
post #3 of 14 (permalink) Old 07-15-2014, 07:39 PM Thread Starter
Curtscat's Avatar
So what sensors tell the computer to change the timing then?
Curtscat is offline
post #4 of 14 (permalink) Old 07-15-2014, 07:59 PM
On my 97 (will be different but most likely very similar on yours) timing is controlled by volumetric efficiency (MAF sensor/RPM relationship) and RPM. Essentially - at x RPM, command y degrees of spark while at z load. There are modifiers to add or subtract timing based on coolant temperature, intake air temperature, open/closed loop (commanded A:F ratio), and EGR flow. There are also functions to reduce or limit timing under certain conditions, e.g. throttle tip in or idle.
All the sensors involved would include MAF, CKPS, IAT, ECT, TPS, DPFE and VSS.
Primarily the PCM commands timing based on the lowest value found in a number of tables with engine load on one axis and engine RPM on the other axis, after applying modifiers for operating conditions (EGR, Temps).
Again - this is the EEC-V method. I don't know how much applies to the EEC-IV.
post #5 of 14 (permalink) Old 07-15-2014, 08:37 PM Thread Starter
Curtscat's Avatar
Great, thanks for the info. Looks like I need to start testing more sensors than I thought. My timing isnt moving.
Curtscat is offline
post #6 of 14 (permalink) Old 07-16-2014, 12:22 AM
There's one thing to check FIRST - check the SPOUT connector. If it opens up (or if the plug is missing), you'll be fixed at 10* BTDC.
Fuelly
RalphP is online now
post #7 of 14 (permalink) Old 07-16-2014, 04:20 AM Thread Starter
Curtscat's Avatar
ok, thanks.
Curtscat is offline
post #8 of 14 (permalink) Old 07-16-2014, 07:26 PM Thread Starter
Curtscat's Avatar
Spout is good.
Curtscat is offline
post #9 of 14 (permalink) Old 07-16-2014, 07:32 PM
What do you get if you measure for voltage across the connector?
post #10 of 14 (permalink) Old 07-17-2014, 07:43 PM Thread Starter
Curtscat's Avatar
1.91 KOEO, and with engine running,it's all over the map. 7 volts and down.
Curtscat is offline
post #11 of 14 (permalink) Old 07-17-2014, 08:25 PM
Sounds off to me, it should be a clean signal. Do you have the EVTM? Time to do some pinpoint tests for a short.
post #12 of 14 (permalink) Old 07-18-2014, 04:33 AM Thread Starter
Curtscat's Avatar
What is an EVTM? I have a DVM with piercing probes.
Curtscat is offline
post #13 of 14 (permalink) Old 07-18-2014, 05:28 AM
http://www.ebay.com/itm/1991-Ford-Th...item35bbd5f719
post #14 of 14 (permalink) Old 07-18-2014, 04:50 PM Thread Starter
Curtscat's Avatar
Thanks Brandon. Bought it and will get it next week.
Curt.
Curtscat is offline
