Random Overheating - TCCoA Forums
post #1 of 18 (permalink) Old 08-23-2014, 09:13 PM Thread Starter
Random Overheating
Anybody else have the 3.8 NA and have issues with random overheating. It'll get hot then I'll let it cool down and its fine. Already replaced the thermostat and its good on fluids
Cloran is offline
post #2 of 18 (permalink) Old 08-24-2014, 09:51 PM
Hate to ask this, but have you checked to see if the head gasket is leaking? When does it overheat?
1badcat95 is offline
post #3 of 18 (permalink) Old 08-25-2014, 12:38 AM
KEVIN8989's Avatar
Why do the 3.8's have such a big problem with blowing head gaskets?
KEVIN8989 is offline
post #4 of 18 (permalink) Old 08-25-2014, 01:53 AM
Originally Posted by KEVIN8989 View Post
Why do the 3.8's have such a problem with blowing head gaskets?
Combination of poor gasket material and bi-metal erosion. The 96/97's got multi-layered steel head gaskets instead of the composite paper gaskets that the 89-95's had. However sources claim that they are all prone to erosion due to electrolysis caused by broken down coolant carrying a positive charge, basically unavoidable due to aluminum heads on an iron block. As stated MLS gaskets are better equipped to handle the difference in expanding and contracting between to unlike metals. Obviously all bets are off as soon as the engine is overheated in either case or with electrolysis or rust caused by improperly maintained coolant or a defective cooling system.
post #5 of 18 (permalink) Old 08-25-2014, 11:19 PM Thread Starter
The only 2 times its done it when I'm driving to fort wayne, IN. About 40 minutes away. I haven't noticed any leaking but then again, I haven't checked the heads rea good either
Cloran is offline
post #6 of 18 (permalink) Old 08-26-2014, 01:50 AM
white lincoln's Avatar
Check if you are losing coolant. Check your oil and coolant for milky color in the oil or floating oil / oil in the radiator fluid.
I found my heads where leaking by pulling all my plugs and inspecting them for rust in the ignition area. Also if the ceramic around the electrode is an off color from the usual ivory white. One of them smelled like gas becasue it fouled out and was no longer firing. See my post here.
But if none of the above is present, try these: If it is the original radiator, look at replacing it. Also, your water pump could be going, look for seeping under the pump where the seep hole is. I ended up replacing my t-stat, then the hoses and then water pump. I was still over heating and it turned out to be the radiator was just old and not cooling anymore. All of these parts can be checked before replacing. Do some research on how to test them before replacing them.
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
white lincoln is offline
post #7 of 18 (permalink) Old 08-26-2014, 04:15 PM
KEVIN8989's Avatar
My engine was rebuilt at around 140,000 miles with new gaskets and timing chain/ tensioners. It should last a while if I keep changing the oil every 3,000 miles and flushing the coolant every six months right? Right now my engine is at 200,000 mi.
post #8 of 18 (permalink) Old 08-26-2014, 09:10 PM
Flushing the coolant every 6 months? Wow.
post #9 of 18 (permalink) Old 08-26-2014, 09:14 PM
89-95 once a year or every 30,000
96-97 once every 2 years or 60,000
with grean coolant or prestone
That's my recommendation anyway.
post #10 of 18 (permalink) Old 08-27-2014, 12:40 AM
That would be every 4-6 years for me.
post #11 of 18 (permalink) Old 08-27-2014, 01:02 AM
That's why I included a time as well. As with any interval it's a whichever comes first type situation.
post #12 of 18 (permalink) Old 08-27-2014, 12:25 PM Thread Starter
I know I need a new water pump so I'm hoping that fixes the issue
Cloran is offline
post #13 of 18 (permalink) Old 08-27-2014, 12:29 PM
Well, Like I said... the system is pretty symple... T-Stat, water pump and radiator. But check to see if you are leaking collant on the block anywhere as well.
But of the pump is going, they tend to just go and not do a random crapping out, but it could be possible. I suspect you have blockage somewhere that keeps blocking the flow of coolant every so often. Like I said earlier, mine was doing the same thing until I replaced all three, T-Stat, pump and radiator.
Good luck.
post #14 of 18 (permalink) Old 08-27-2014, 12:29 PM
KEVIN8989's Avatar
How many miles does you motor have?
post #15 of 18 (permalink) Old 08-27-2014, 12:32 PM Thread Starter
No idea on the mileage. ODO didn't work when I bought it. I did the thermostat a couple weeks ago. Wanna do the water pump and new hoses soon
Cloran is offline
post #16 of 18 (permalink) Old 08-27-2014, 01:37 PM
Get it from RockAuto and use the 5% discount code:
Your discount code is:
2470597723052146
How to Use Your Discount Code
Enter the code above in the "How Did You Hear About Us?" space on the checkout page (above your payment information). Do not enter any other text in that space or the discount will not apply. Click the "Apply" button and your discount will be subtracted from your parts order total.
Please note: Discount only valid for orders placed online. Code must be entered before order is submitted.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.
This discount code expires on October 26, 2014 so don't wait!
Thanks again for buying your auto parts at RockAuto!
www.RockAuto.com
post #17 of 18 (permalink) Old 08-27-2014, 03:52 PM
jco1385's Avatar
You could also try local, as I posted in another thread a few days back.
Originally Posted by jco1385 View Post
For the record, there's an Advance Auto online discount code (TRT30) to save 30% and pick up in store. This brings their prices in check with Rockauto, minus the shipping and wait. It's worth looking to see if they're available local.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #18 of 18 (permalink) Old 08-27-2014, 04:05 PM
That too!
