Confused overheating - TCCoA Forums
post #1 of 5 (permalink) Old 11-19-2014, 07:05 PM Thread Starter
I have a 1990 3.8na, and I'm getting really weird things with it. Some days the temp gauge will almost overheat, then fluctuate. I have heat randomly, the blower work and so do my flaps. It does tend to smoke IMO alot more then it should. I have no idea of mileage, odometer stop at 126k. I have replaced thermostat and bleed the system. When i go to take the radiator cap off, its got pressure behind it
Cloran is offline
post #2 of 5 (permalink) Old 11-19-2014, 07:38 PM
I'd bleed any air out of the system first, but otherwise it sounds like signs that the head gaskets might be on their way out.
post #3 of 5 (permalink) Old 11-19-2014, 08:07 PM Thread Starter
Ive bled it more then once....Thats what I was afraid of
Cloran is offline
post #4 of 5 (permalink) Old 11-19-2014, 11:30 PM
decipha's Avatar
you can get a coolant check kit from autozone to see if you have combustion gases in the coolant you'll know in no time
or do a compression test
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #5 of 5 (permalink) Old 11-20-2014, 04:02 PM Thread Starter
Ill look into that, thanks
Cloran is offline
