Water socket on top of pump - TCCoA Forums
post #1 of 5 (permalink) Old 11-19-2014, 09:20 PM Thread Starter
white lincoln's Avatar
The water socket on the top of my water pump is leaking.
[IMG][/IMG]
What is the best way to tighten this down? The original O ring is long gone and tried another one from my stock. Is there a better way to seal this?
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
white lincoln is offline
post #2 of 5 (permalink) Old 11-22-2014, 08:28 AM
Urambo Tauro's Avatar
Rtv
Urambo Tauro is offline
post #3 of 5 (permalink) Old 11-22-2014, 11:54 PM Thread Starter
I didn't know you could use sealant on the fitting.
I tightened it down as far as I wanted to go before I felt it would strip the aluminum housing and it is not leaking as much. I will pull it and reseal it. Maybe the O ring I am using is actually causing the leaking because it won't let the fitting seat correctly.
Thanks!
post #4 of 5 (permalink) Old 11-23-2014, 08:53 AM
The correct answer is of course to clean the surfaces and have a proper sized o-ring. But I don't like the way this socket is put together. The bolt seems to compress the o-ring in a slightly lopsided fashion. I'm sure it worked out just fine from the factory when everything was new.
A bit of RTV will do the job well and won't hurt anything. It's probably a good idea to use the grey stuff formulated for water pumps and thermostats.
post #5 of 5 (permalink) Old 11-23-2014, 10:11 AM Thread Starter
Before i put the fitting back in, i sanded the rust off then sprayed it with high engine heat paint to help keep the rust down.
I will look for an OEM o-ring for the fitting.
