Car runs like crap when it is cold - TCCoA Forums
post #1 of 15 (permalink) Old 12-14-2014, 05:12 PM Thread Starter
white lincoln's Avatar
When I start my Cougar cold, it runs poorly, rough and no power. Once it is warmed up, it is running okay, but not as smooth as before.
Could this be the IAC? I have not run codes yet, have NOT had time with all the Christmas stuff my wife has me doing.
I had wondered if the one of the injectors is not spraying correctly as well.
No more water leaks and got my new hood shock in!
Thanks!
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
white lincoln is offline
post #2 of 15 (permalink) Old 12-14-2014, 05:25 PM
Start simple, it's probably electrical.
ECT, MAF, IAT are the first little culprits I think of, with the MAF being the most common. A super simple test is to just unplug the MAF and start the car. If it's better, you know what the culprit is. If nothing changes, you've ruled it out (for the most part).
post #3 of 15 (permalink) Old 12-14-2014, 05:28 PM
Exact problem I had, then it got worse and my CEL came on. It was bad plugs and nasty MAF.
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #4 of 15 (permalink) Old 12-14-2014, 05:55 PM Thread Starter
Interesting.
I have new plugs and just cleaned the MAF.
I need to run codes before I do anything else.
Thanks!
post #5 of 15 (permalink) Old 12-14-2014, 06:38 PM
Unplug the MAF like theterminator93 advised. When I did that the car ran perfect. That is what lead to the discovery and all the help from here.
2011 Kia Sorrento
1996 T-bird
post #6 of 15 (permalink) Old 12-14-2014, 09:18 PM Thread Starter
Unplug the MAF like theterminator93 advised. .
Will do.
Let you know what happens.
While looking at the coolant sensor, I noticed anti-freeze coming from the upper hose at the rad. Turned the clamp around to get more clamp on the area BEFORE the rim. It stopped leaking.
post #7 of 15 (permalink) Old 12-14-2014, 09:19 PM Thread Starter
Did you replace the MAF or just clean it up with MAF cleaner?
post #8 of 15 (permalink) Old 12-14-2014, 11:06 PM
Cleaned it...
2011 Kia Sorrento
1996 T-bird
post #9 of 15 (permalink) Old 12-15-2014, 09:48 AM Thread Starter
Cleaned it...
Found out last night I lost my T-20 security torx bit. Ugh....
post #10 of 15 (permalink) Old 12-15-2014, 12:54 PM Thread Starter
I pulled the MAF connector, it started just fine, but it died when I put it in gear.
Still have an issue besides the MAF.
post #11 of 15 (permalink) Old 12-15-2014, 05:52 PM
1995 cougar xr7's Avatar
Mine doing the same thing. I haven't had time to check it out
1995 cougar xr7 is offline
post #12 of 15 (permalink) Old 12-15-2014, 06:45 PM Thread Starter
That is why I was thinking it might be the IAC.... NEED TO RUN CODES ON THIS CAR!!!! ARGH!
post #13 of 15 (permalink) Old 12-15-2014, 08:58 PM
Yank the IAC and see if it's gunked up. It may be possible to clean it out if it's very dirty.
post #14 of 15 (permalink) Old 12-26-2014, 03:50 PM
I had a 1992 sable with a 3.8L, One thing you should check always is the EGR sensor, on the Sable/Taurus it was mounted right ontop of the system, mine melted.
steveg1988 is offline
post #15 of 15 (permalink) Old 12-26-2014, 07:12 PM Thread Starter
Good idea, thank you. But a bad EGR won't leak oil / brake fluid into the exhaust tube to the EGR and should have shown up on a complete diag.
Thanks!
