Flat spot in acceleration - TCCoA Forums
post #1 of 2 (permalink) Old 02-04-2015, 09:37 PM Thread Starter
white lincoln's Avatar
I have noticed lately that my 3.8 has a flat spot in the peddle when accelerating. The engine seems to do nothing even though I am pressing on the peddle. The car is still moving, but there is little or no acceleration until a few seconds later it just picks up and goes. Other than that, the engine is running fine, a little rough still after the brake booster bleeding into the EGR tube.
On another note: How do I get rid of the brake fluid burning smell after having the brake master cylinder and booster replaced? Do I blow some sea foam in the vacuum line to the EGR tube? Or is the catalytic converter going to burn the brake fluid for a while before it is gone?
Thanks!
1995 Lincoln Town Car Signature Series - 200k!
1994 Mercoury Cougar XR7 - 150k and still going.
I've had too many other cars to mention...
white lincoln is offline
post #2 of 2 (permalink) Old 02-17-2015, 12:07 AM Thread Starter
Possible conclusion
Seems that after having the brakes done, the car is running better and better. I ran some seafoam in the intake and poured a can in the tank. The flat spot is disappearing and the car is regaining its pep it had before the brakes went out and leaked into the intake.
Brake fluid in the intake is just nasty....
And the smell is gone now after driving the car a lot to burn off and out any of the brake left in the intake.
