Anti-Slosh Module on 91 Base Gauges? Gas gauge keeps going past full - TCCoA Forums
post #1 of 8 (permalink) Old 06-28-2015, 09:30 AM Thread Starter
Gas Gauge Keeps Going Past Full - Cleaned Anti-Slosh Chip & It Did Not Fix it
I have a 91 3.8 base thunderbird so it's just the basic speedo, temp, and gas gauge set up. Yesterday the gas gauge randomly started to go past full (1/8-1/4 past full) but it only has about a half-tank of gas. I pulled the cluster today, cleaned the anti-slosh chip and made sure it was locked in but it didn't fix the issue.
It constantly goes past the full mark anytime you turn the key to the on position even before the engine is started. Is there anything else I can check that's simple that's cheap (really trying to avoid messing with the sender, I would have to pay a shop to do it as it's too dangerous to do on the street)? Maybe the gauge itself is bad? It was making an odd noise about 2 weeks back but it didn't affect the operation of the gauge.
Thanks for your time and your help.
Last edited by 06jeep; 06-28-2015 at 03:48 PM. Reason: Added information, shortened post
06jeep is offline
post #2 of 8 (permalink) Old 06-29-2015, 01:03 PM
Most of these cars will do that, there is no fix. Mine will start reading accurate at 3/4
steveg1988 is offline
post #3 of 8 (permalink) Old 06-29-2015, 05:41 PM Thread Starter
I think your thinking of when you fill it up, it'll read near the full mark for 70-90 miles then start reading accurately right around 3/4s of a tank. I'm used to that as it's done that before but it reads above full all the time now since Saturday. I haven't put any gas in it either and about 230 miles have been traveled on this tank, mostly city/highway mixed driving so it's likely around 20-22mpg average. All highway it does 24-27mpg depending on the speeds/grade.
There's definitely less than a half of tank of gas in it now (probably close to a 1/4 left based on the miles traveled) and it was reading correctly at slightly above the half line until a hard stop in the pouring rain (didn't lock up the tires but it was a hard stop to avoid someone pulling out without looking) on Saturday. Hasn't read correctly since then, it'll go straight to above the full line as soon as the fuel pump kicks on or soon as you start the car.
06jeep is offline
post #4 of 8 (permalink) Old 06-29-2015, 05:46 PM
I would put injector cleaner into it, cannot hurt
post #5 of 8 (permalink) Old 06-30-2015, 09:12 AM
After the injector cleaner, if that doesn't help any, I'd swap that anti-slosh board. Yes, they can fail, and since they are what actually drives the fuel gauge ...
Your OTHER choice is to grab a multi meter, and check the resistance to ground of the wire from the sending unit, or at least the voltage across it. The factory service manual has you checking the resistance to see if it's in range.
No, I don't have my book open in front of me, and my PDF version isn't reinstalled on my "new" system either, or I'd give you the wire color and the range you should see.
What you're doing with that is, if it's in the middle of the range for a tank of gas, and the gauge is full high, the problem is the anti-slosh board or the gauge (luckily, you can swap just the gauge out of a base cluster). If, however, it's at the full-tank mark, then it's the sending unit or the wiring to the sending unit bad.
There's always the possibility that the float is "stuck". I had to repair the sending unit on my Dakota pickup, and as a result of my repair, when it gets down low enough to tag the "Low Fuel" light, it tends to stick there until I refill the tank.
Fuelly
RalphP is offline
post #6 of 8 (permalink) Old 07-01-2015, 04:00 PM Thread Starter
Injector cleaner and 93 octane fixed it! I filled the tank and it works fine now. Thanks for all the help, I definitely might buy a set of base gauges as a backup in the future.
06jeep is offline
post #7 of 8 (permalink) Old 07-07-2015, 10:54 AM
The octane does not make any difference. Unless it is Shell Premium, I've looked into it and that has the most PPM of injector cleaner.
post #8 of 8 (permalink) Old 07-07-2015, 11:48 PM
More than Chevron or Texaco? I'm impressed.
Not that it matters much - I run mostly Shell 87 octane in the Cougar, and 89 octane (due to running 14* BTDC timing on it) in the Dakota.
Fuelly
RalphP is offline
