PCM question - TCCoA Forums
post #1 of 7 (permalink) Old 06-16-2016, 11:41 PM Thread Starter
BADRACR1's Avatar
PCM question
I believe my 1997 3.8 needs a PCM. I get a cam position sensor code even after replacing the sensor. Another 97 I had did the same thing. PCM was the issue. Mine is #F6SZ12A650AF. I found on F6SF code on EBay. Will it work? What's the difference? I remember seeing on here someone could flash the units for stock or improved performance. Can this be done? Who was it? I am in 37412. Thanks.
1997 LX/LE Moonlight Blue, 65k, factory chrome wheels, all original except cd player!
BADRACR1 is offline
post #2 of 7 (permalink) Old 06-17-2016, 12:56 PM
jco1385's Avatar
You want to match the 'catch code' that is on the PCM. It is a 4 digit alpha-numeric like shown in the pic below. Otherwise, one with the same configuration (3.8NA/4R70W/EEC-V/OBDII) should work but it may have a slightly different tune. I have the RCX4 unit that is shown if you think it will work for you (from a 96/97 3.8L Thunderbird/Cougar). Dave Dalke over at Super Coupes Unlimited sells and does mail-order tunes for the SCT chips.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #3 of 7 (permalink) Old 06-17-2016, 03:58 PM Thread Starter
BADRACR1's Avatar
I will check mine. Thanks.
BADRACR1 is offline
post #4 of 7 (permalink) Old 06-20-2016, 08:05 AM
T6Rocket's Avatar
Easy to check, open the hood and the code is on the passenger fender.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 7 (permalink) Old 06-24-2016, 07:36 PM Thread Starter
BADRACR1's Avatar
Thanks. That is easier than pulling the PCM out. Any idea where it it on the fender? I don't remember seeing anything.
BADRACR1 is offline
post #6 of 7 (permalink) Old 06-25-2016, 05:58 AM
If it's the original fender, there should be a sticker with the code on it near the hood hinge.......at least that's where mine is!
post #7 of 7 (permalink) Old 06-26-2016, 11:14 PM Thread Starter
BADRACR1's Avatar
Yeah, it's original. But twenty years old! Will try to look tomorrow. Thanks.
BADRACR1 is offline
