96 bird - TCCoA Forums
post #1 of 7 (permalink) Old 08-08-2016, 03:01 AM Thread Starter
96 bird
So I have changed my fuel pump my fuel filter and my fuel pressure regulator and my car still will not start Im think it may be the maf sensor but I'm not sure it's sounds like it want so start but will not an some times it will start but shut off after a few secs
Newguy92285 is offline
post #2 of 7 (permalink) Old 08-08-2016, 06:36 AM
Darrin's Avatar
Do you have fuel pressure? Can you hear the pump running before you try to start it?
D
Darrin is offline
post #3 of 7 (permalink) Old 08-08-2016, 10:55 AM
TwoHaggard's Avatar
You can test the pins coming in and out of that box that mcm51 is talking about to make sure the relay is bad before you go swapping more parts out and you don't need too.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #4 of 7 (permalink) Old 08-08-2016, 02:24 PM Thread Starter
I took a five gallon can and put the fuel filter line in there and turned the car on and the pump never shut off I hook up a pressure regulartor to the car it's about 35-40 psi I have never had that before so I'm getting the fuel just not starting
post #5 of 7 (permalink) Old 08-08-2016, 04:27 PM
T6Rocket's Avatar
Maybe look at the crankshaft position sensor. Does the tach register RPM when cranking or just sit at 0?
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #6 of 7 (permalink) Old 08-08-2016, 06:51 PM
Draetech09's Avatar
Check your (TPS) throttle position sensor. Seems like its not getting fuel and starts for a few seconds and dies. Sounds just like the symptoms I had when mines went out. Its not very expensive either.
If you Fail to plan, then you plan to Fail!
I'll forever bleed Ford Blue
Drae
Draetech09 is offline
post #7 of 7 (permalink) Old 08-09-2016, 07:22 AM
jco1385's Avatar
Have you tested the coil pack? Check all of the connections for corrosion. What were the symptoms leading up to you changing the pump?
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
