Intake Manifold Gasket replacement problems - TCCoA Forums
post #1 of 4 (permalink) Old 02-25-2018, 09:44 PM Thread Starter
Joeavamist's Avatar
so I replaced my Gaskets last night and finally got everything put back together, and went to start the enginne, which started for a half second, then shut off completely. like it was drained. I am willing to believe i connected something wrong somewhere but i have no clue where to look first. Any help is greatly appreicated.
Whaddya mean I can't have another? This one is Black and you love black!
Joeavamist is offline
post #2 of 4 (permalink) Old 02-26-2018, 06:15 PM
What year and which intake gaskets (upper to lower or lower to heads)? Will the starter crank the engine?
post #3 of 4 (permalink) Old 02-26-2018, 06:17 PM
Did you plug the fuel lines back in? Hey, stuff happens...
Go thru each step, and make sure everything is back where it's supposed to be.
If it ran, it's probably NOT the spark. Sounds like no fuel.
post #4 of 4 (permalink) Old 03-04-2018, 07:06 AM
bowez's Avatar
Check the inertia shut off. Well I guess the best thing would be to check fuel pressure.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
