1989-1993 Supercoupes with AOD: What rpm do you hit when in overdrive at 55mph? - TCCoA Forums
 3Likes
  • 2 Post By MadMikeyL
  • 1 Post By Zep5.0
post #1 of 25 (permalink) Old 07-16-2019, 03:20 PM Thread Starter
BigxN8's Avatar
I'm curious to see what rpm is to compare with the 2.73 and 3.08
BigxN8 is offline
post #2 of 25 (permalink) Old 07-16-2019, 04:32 PM
All AOD equipped SC's had 3.27 gears and 225/60/16 tires. 4th gear in an AOD is 0.67:1, so 55mph in OD with 3.27s would be just over 1500rpm. 3.08s would be about 1450rpm, and 2.73s would be about 1300rpm.
post #3 of 25 (permalink) Old 07-16-2019, 04:36 PM
The biggest problem is that there's not enough torque to run 2.73s and the 1st gear in the AOD.
Well, there is, but you'll lose out on the first part of the 1/4 mile due to having to get up into the torque curve.
Why are you looking for longer legged gearing? *is curious*
Fuelly
RalphP is offline
post #4 of 25 (permalink) Old 07-16-2019, 05:37 PM Thread Starter
BigxN8's Avatar
I have 2.73s on my car and it really kills the acceleration. I'm thinking about going with the 3.27 to increase 0 to 60, but I also want the good mpg. Also, i dont have a super coupe, I have the 5.0. The reason I'm asking is because it's the "best" thing to compare it to 😕
BigxN8 is offline
post #5 of 25 (permalink) Old 07-16-2019, 09:17 PM
Actually, no, the SC isn't the "best" thing to compare it with; the best thing is a 5.0HO.
The 3.08 was the stock issue most years; and it does tolerable at best. A 2.73? I bet that car feels like a dead pig off the line.
I've got some 3.55s to go into Ruby as I redo her drivetrain; 3.73 is about as stiff as I'd go for a highway-also car, but YMMV natch.
Fuelly
RalphP is offline
post #6 of 25 (permalink) Old 07-17-2019, 08:29 AM
T6Rocket's Avatar
I think this is a trick question because who would actually drive 55?
They put 2.73's in V8 T-Birds for years, pretty much all years in the 70's and 80's. In the 60's they used 2.75's with the 429's. Talk about a waste of big block power.
I am curious which year the OP has, and if he actually has 2.73's. If it's an 88 or older, definitely!
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #7 of 25 (permalink) Old 07-17-2019, 09:37 AM Thread Starter
BigxN8's Avatar
Not a trick question. I own a 91 5.0 and I'm using it for daily driving. The roads I'm getting on are 55 mph. The 5.0s in 1991 were equipped with either a 2.73 or a 3.08
BigxN8 is offline
post #8 of 25 (permalink) Old 07-17-2019, 01:43 PM
That’s not true. Unless you or someone before you changed the rear gears, you have either 3.08s or 3.27s. The only MN12s that came factory with 2.73s were the 5-speed SCs. The fox body cars could be had with the AOD and 2.73s, but they also had shorter tires, and were at least 400lbs lighter.
post #9 of 25 (permalink) Old 07-18-2019, 12:29 PM
Zep5.0's Avatar
This is incorrect -I have a 91 Cougar LS, 5.0HO, stock 2.73 rears switched to 3.73's about a 1 second improvement in 1/4 mile times, LOL. 5000RPM shift out of first was at 60 mph or so
Zep5.0 is offline
post #10 of 25 (permalink) Old 07-18-2019, 12:31 PM
Zep5.0's Avatar
And yes, horribly slow until about 3800 RPM. Down shifting at 35MPH was fun though, before I knew how slow it still was...
Zep5.0 is offline
post #11 of 25 (permalink) Old 07-18-2019, 04:30 PM
What does the door tag list under axle?
post #12 of 25 (permalink) Old 07-18-2019, 06:18 PM
KEVIN8989's Avatar
My SC RPM at 55 is 1600. I never heard of 2.73 gears on a auto MN12, I wonder if Matt knew about that.
KEVIN8989 is offline
post #13 of 25 (permalink) Old 07-18-2019, 07:57 PM
Zep5.0's Avatar
I'm about an hour away from the car unfortunately. I'll look at the tag when I get a chance. Was under 1400 rpm at 55, just over 1600 at 70. I worked at a Ford dealership during college when I did the gear swap. Discussing options with the Ford tech we decided to find a junkyard rear with the trac-lok to build while I was still driving the car with the 2.73 open diff. I've been mistaken before but don't think I am here....
Zep5.0 is offline
post #14 of 25 (permalink) Old 07-18-2019, 08:11 PM
It could be that the junkyard diff you got had 2.73s, since all the early SCs got a trak-lok, and nobody wanted the 2.73s so they were always cheaper than the 3.27 ones out of the autos. The door tag will tell for sure what was originally in there though.
post #15 of 25 (permalink) Old 07-19-2019, 09:06 PM Thread Starter
BigxN8's Avatar
It could just be that I have a 5.0 with 2.73s -_-
BigxN8 is offline
post #16 of 25 (permalink) Old 07-20-2019, 12:16 AM
Zep5.0's Avatar
I'll take a pic of my tag tomorrow. Fairly certain mine was 2.73 as well.
Zep5.0 is offline
post #17 of 25 (permalink) Old 07-20-2019, 01:27 AM
KEVIN8989's Avatar
Where does it say what gears it has on the tag?
post #18 of 25 (permalink) Old 07-20-2019, 05:34 AM
Kevin,
3.27 traction-lok.
Axle Codes
post #19 of 25 (permalink) Old 07-20-2019, 11:40 AM
Zep5.0's Avatar
Axle code is 8. 2.73 open diff, 91 5.0 LS. And yes it was a dog off the line.
Zep5.0 is offline
post #20 of 25 (permalink) Old 07-21-2019, 12:46 PM
KEVIN8989's Avatar
I wonder if they made any 3.8 n/a with 2.73 gears, that would be so slow. Whats your freeway mpg?
post #21 of 25 (permalink) Old 07-21-2019, 06:15 PM
Zep5.0's Avatar
I'd get 27-28 mpg on 2 Lane roads going 62 in a 55mph. 72 on the freeway around 24, if I remember correctly. Switched to 3.73s 13 years ago. Been in the garage most of those years after trans went out.
KEVIN8989 likes this.
Zep5.0 is offline
post #22 of 25 (permalink) Old 07-21-2019, 06:23 PM
KEVIN8989's Avatar
What was your mpg with 2.73
post #23 of 25 (permalink) Old 07-21-2019, 06:56 PM
Zep5.0's Avatar
That was with the 2.73. can't say I really cared to check after the switch to 3.73. maybe 20 highway? Rpm was closer to 1700 at 70 iirc.
Zep5.0 is offline
post #24 of 25 (permalink) Old 07-24-2019, 06:30 PM
gordonm1's Avatar
A big FWIW
I recently switched to 3.73 from my stock 3.08 5.0 lx and mpg went from 24.5 mpg at 74 mph to maybe 21 or 22 (any long drive involves hills in my area). I don't do long trips with it since doing mods but it was a 21% gear reduction using my math so a fuel economy reduction is expected/guaranteed when you are in high gear and past about 1500 rpm.
As far as 0-60mph went for me. I switched to 3.73's in part to improve the time since it had to shift to second before it would hit 60mph. I remember not being able to hit 60 mph in first without hitting the 5000 rpm red line and I won't try it now with 3.73's. My tach does have a 500 rpm echo or something that can't really be trusted at high or WOT. Nobody has offered to time me so 0-60 is still a mystery.
gordonm1 is offline
post #25 of 25 (permalink) Old 07-24-2019, 06:52 PM
Put an acceleration app on your phone, and you can see the shifts.
Should be able to see the timing as well.
Similar Threads
oil gauge dropping low as I hit 3,000 rpm weasel97-TBird General Tech 19 04-19-2015 09:41 PM
Xenon Air Dam for 1989-93 Supercoupes SC V8 Bird Parts For Sale 6 08-18-2008 11:22 AM
Congress considers reinstating national 55mph speed limit stangboy7 Miscellaneous 27 07-11-2008 01:40 PM
1989 mustang VS 1989 T-bird EFI Jim Allen Engine - 5.0L & 5.8L 3 07-25-2007 03:54 PM
is 182mph in a 55mph a little too fast? Shawn40th Miscellaneous 14 11-22-2003 08:05 PM
