Belt Tensioner Bearing Change - TCCoA Forums
post #1 of 10 (permalink) Old 10-29-2003, 10:41 AM Thread Starter
PCD
Confirmed V6 Nut
Has anyone done this or do you just swap the entire tensioner?
If you've changed the bearings, where did you get the bearings and how did you specify them?
If you just replace the entire tensioner, is a "recycled" tensioner from the local junk yard ok, of go for a new one?
PCD is offline
post #2 of 10 (permalink) Old 10-29-2003, 10:45 AM
jk69cat's Avatar
depends if you feel lucky, i can get you one for around 65.00 plus ship. pn is
f4sz6b209b.
jk69cat is offline
post #3 of 10 (permalink) Old 10-29-2003, 11:01 AM Thread Starter
PCD
Confirmed V6 Nut
Thanks, Justin.
Right now I'm gathering all my options. $$$ are tight!
Oh, do you know if Rob is selling the springs from that parts car?
PCD is offline
post #4 of 10 (permalink) Old 10-29-2003, 11:55 AM
jk69cat's Avatar
believe me i know how tight cash is, im trying to get all the stuff to finish my car. you could call him and ask. im sure he would but they are pia in the rear to pull the way he has the car sitting.
jk69cat is offline
post #5 of 10 (permalink) Old 10-29-2003, 01:46 PM Thread Starter
PCD
Confirmed V6 Nut
I think my wife threw out his number.
Just let him know I might be interested in his springs.
PCD is offline
post #6 of 10 (permalink) Old 10-29-2003, 02:39 PM
jk69cat's Avatar
ok i can do that.
jk69cat is offline
post #7 of 10 (permalink) Old 10-29-2003, 03:18 PM
Send a message via AIM to rzimmerl
if the bearings are bad in the pulley i would just replace that instead of the tensioner, you sure it isnt the idler pulley maikin the noise those ususally go bad
1990 SC AOD 1.7L AR....11.75 @118
441 RWHP 435 RWTQ
rzimmerl is offline
post #8 of 10 (permalink) Old 10-31-2003, 08:26 AM Thread Starter
PCD
Confirmed V6 Nut
Well, I don't think it the belt tensioner anymore.
I get the bearing squeal only when I start the engine when it is dead ice cold. The sound is centered and in front of the engine. If there's any warmth in the "water", the noise goes away. I'd better start pricing water pumps.
Any places or brands not to use?
PCD is offline
post #9 of 10 (permalink) Old 10-31-2003, 09:18 AM
jk69cat's Avatar
i can do you for a new ford one for 122.00 pn f8zz8501aa
jk69cat is offline
post #10 of 10 (permalink) Old 11-01-2003, 06:33 PM Thread Starter
PCD
Confirmed V6 Nut
I was a total doofus!
My problems were not the water pump. The bearings in my Alternator and my lower belt tensioner were BOTH going/gone.
Much thanks to Mike and Al of the Super Coupe Club of Iowa.
PCD is offline
