Ignition Problem - TCCoA Forums
post #1 of 6 (permalink) Old 11-01-2003, 09:53 PM Thread Starter
Angry Ignition Problem
OK....I am driving my wife's car (97 3.8L Bird) and I stop at a light. I try to go and the car barely moves, I mean even with the accelerator almost floored. I look down and notice that my service engine light is blinking. So I pull over. I checked the codes once I got to my house and got my scanner, and I got a P353, P302, and P306. Which is Ignition coil C pri./Sec malfunction or something like that, and misfires on cylinders #2 and #6. I had to get the car running, so I said screw it and bought a new coil. The car ran fine for about 10 minutes and now it is doing the same thing and shooting me the same codes.... Any idea as to what this problem might be if it isn't a coil?? Any help or advice is appreciated.
badazzbird is offline
post #2 of 6 (permalink) Old 11-01-2003, 10:24 PM
Well the first thing to look at when you got trouble running like that is to clean the MAF. It's easy, it's free, and it's quick. Unfortuantly I don't know as much about the ignition system as I should. I'm sure that someone else here does I'm sure.
93SC is offline
post #3 of 6 (permalink) Old 11-02-2003, 12:15 AM Thread Starter
I cleaned the MAF and it made no difference.....any other ideas??
post #4 of 6 (permalink) Old 11-02-2003, 03:31 PM Thread Starter
Is it possible that it could be the crankshaft sensor?? Or am I way off base here?
post #5 of 6 (permalink) Old 11-03-2003, 11:53 AM
Trumpeter Extraordinaire
IronChopz's Avatar
On the P0353 code, one of the first items to check is for "spark at crank." If spark is not consistant, check spark plugs and wires. Other possible causes: incorrect voltage to the coils or PCM, or a harness problem.
IronChopz is offline
post #6 of 6 (permalink) Old 11-04-2003, 11:18 AM Thread Starter
I had to bite the bullet and take it to Ford.... it turns out that the PCM took a crap. But they are fixing it for me. Thanks for the help guys.
