Idle problems....with new IAC - TCCoA Forums
post #1 of 1 (permalink) Old 11-06-2003, 11:26 AM Thread Starter
Send a message via Yahoo to 59bisquik
Question Idle problems....with new IAC
Well a couple of months back my car was idling around 2000 and wouldnt come down. I replaced the IAC, and it went back to normal. All the sudden it is doing it again. Only difference being that now when the car is started it revs to 2000 and then slowly creeps down after about 30 seconds. But never drops to as low as it should. If I unplug it while it is at the higher rpm it goes back to normal immediately. This tells me that the valve is working properly I would think. There are no codes or engine light. Any ideas guys??? 94 3.8
94 3.8 Thunderchicken
59 Chevy Biscayne undergoing frame off rodstoration 383/Hilborn Stack EFI
54 Ford Customline Coupe 351/AOD
59bisquik is offline
