215/220 cam with 1.8 rockers? - TCCoA Forums
post #1 of 61 (permalink) Old 11-19-2003, 04:23 PM Thread Starter
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I'm getting in on a group purchase over at v6power.net for custom ground cams from RGR and he emailed me a "cam form" where you fill out info and plans for your car and he "prescribes" a cam grind. Well he told me the best grind for a vorteched car with 1.8 rockers and big valve ported heads would be 215/220. I'm thinking that an enormous emount of lift (although I think the more the better) but my worries are that I could have a piston/valve collision with that amount of lift. He said he was going to find/make springs to suit that amount of lift.
If I ever stroked the block to 4.2 would they collide?
-Thomas
Thomas is offline
post #2 of 61 (permalink) Old 11-19-2003, 07:17 PM
when you stroke a motor, doesnt the the TDC stay the same and the pistons just travels down in the block further? so then if the valve isnt hitting the piston to being with, it shouldnt when you stroke it.... can someone verify that? -greg
glowing escape is offline
post #3 of 61 (permalink) Old 11-19-2003, 08:00 PM Thread Starter
Uber Luber
Thomas's Avatar
well there's compression ratios, flat and dished pistons that all change for far the piston is from the valves. Anyways, does anyone know the answer to my question? Need to know before I buy one and the GP is right now at a good price.
-Thomas
Thomas is offline
post #4 of 61 (permalink) Old 11-19-2003, 08:01 PM
-Thomas
you should be able to reuse your pistons that you have, and besides, if youre running boost, you dont exactly want to up compression without building up the bottom end quite a bit... -greg
post #5 of 61 (permalink) Old 11-19-2003, 08:09 PM Thread Starter
Uber Luber
Thomas's Avatar
The cam won't be going in until I get ported heads and a vortech. that grind is waaay too much for an NA engine with stock heads. I won't go past 8psi until I put in a 4.2 with forged internals. Which is why I want to know if that cam will work with a 4.2 as well as a 3.8.
-Thomas
Thomas is offline
post #6 of 61 (permalink) Old 11-20-2003, 02:35 AM Thread Starter
Uber Luber
Thomas's Avatar
Anybody? Please?
-Thomas
Thomas is offline
post #7 of 61 (permalink) Old 11-20-2003, 08:24 AM
i went with teh 207/215 cam with the 1.8rrs He told me back then he didnt think the springs could handle much more lift than that. remember those 1.8s are lift multipliers. there's a thread here somewhere on the math. i was greatly satisfied with my cam/rr packgage and the lope )
when we put em on, we could only get a cpl threads even after backing the adjusting nut all the way back. i got the adj kind.
RobinCali is offline
post #8 of 61 (permalink) Old 11-20-2003, 10:35 AM Thread Starter
Uber Luber
Thomas's Avatar
Yeah I think RGR said they were going to try and find springs that will work, he said they had a new conical design spring coming out. And if it wasn't enough he'd make custom ones lol.
-Thomas
Thomas is offline
post #9 of 61 (permalink) Old 11-28-2003, 11:03 AM
Thomas, I have the 216/225 cam in mine and the PnP heads had Comp Cams high lift valve springs on them and I never had any problem with it... Remember Thomas, my heads and cam are up for sale...
Spike is offline
post #10 of 61 (permalink) Old 11-28-2003, 12:44 PM Thread Starter
Uber Luber
Thomas's Avatar
216/225 would be way more than any aftermarket springs could handle with my 1.8 rockers or else I might jump on it. And as for the heads, I need something more around stage 5 for the amount of power I'm hoping to get. I only know of 2 places that makes the kind of heads I'm wanting.
-Thomas
Thomas is offline
post #11 of 61 (permalink) Old 11-28-2003, 12:47 PM
wait, you're saying that 216/225 is way more than aftermarket springs can handle??? what the hell do you think they make AFTERmarket springs FOR! lol Good luck on the heads and everything man, I hope you have more luck than me!
Spike is offline
post #12 of 61 (permalink) Old 11-28-2003, 12:50 PM Thread Starter
Uber Luber
Thomas's Avatar
well I guess it depends on how much lift the cam gets. But I've already got my cam ordered anyway. 1.8 roller rockers multiply the lift of the cam.
-Thomas
Thomas is offline
post #13 of 61 (permalink) Old 11-28-2003, 03:43 PM
youre gonna luv the lope man....
heheh.
btw, know anybody sellin a mustang?
post #14 of 61 (permalink) Old 11-28-2003, 09:06 PM
I really don't think the greater duration will stress your springs. If the cam has greater lift, that will stress your springs more. I believe the issue is how far your spring gets compressed, and how abrupt or gradual the changes are.
edit: To clarify, what I am getting at is that a 216/220 cam with with .500 lift shouldn't stress your springs much more than a 207/215 cam with .500 lift. But it will stress the springs more than a 216/220 cam with .450 lift. See what I mean?
Steve
S_Mazza is offline
post #15 of 61 (permalink) Old 11-28-2003, 10:54 PM
thomas is right, the roller rockers are a multiplier.
post #16 of 61 (permalink) Old 11-29-2003, 05:59 AM Thread Starter
Uber Luber
Thomas's Avatar
yeah I know what you mean. He said he could grind me a 215/220 cam with .560 lift but could also do a 215/220 with .600 lift. The one with the higher lift will give me more low end torque is what he said. So I'm goin with that. He just found the springs that can handle that amount of lift and they cost more than the cam does lol.
-Thomas
Thomas is offline
post #17 of 61 (permalink) Old 11-29-2003, 11:00 PM
Wow, 0.600 is a lot of lift. Those must be some springs, man. How extreme is your engine going to be?
Steve
S_Mazza is offline
post #18 of 61 (permalink) Old 11-30-2003, 12:09 AM Thread Starter
Uber Luber
Thomas's Avatar
eventually a 4.3L with a vortech. Hoping to hit high 11's when done AT LEAST. I will not be satisfied without 11's.
Yeah you know the springs hold a lot of lift when they cost more than the actual cam hehe.
I just found a set of ported heads with 1.94 and 1.6 valves so I'm in luck. This setup is going to be awesome.
-Thomas
Thomas is offline
post #19 of 61 (permalink) Old 12-01-2003, 12:11 AM
Cool. I look forward to seeing the results.
Steve
S_Mazza is offline
post #20 of 61 (permalink) Old 12-01-2003, 11:48 AM
T-bird4vr's Avatar
Send a message via AIM to T-bird4vr
You're nuts Thomas, you know that right?
Julian
T-bird4vr is offline
post #21 of 61 (permalink) Old 12-01-2003, 12:47 PM Thread Starter
Uber Luber
Thomas's Avatar
Yes thank you. BTW where ya been? Are you avoiding me? [email protected]
-Thomas
Thomas is offline
post #22 of 61 (permalink) Old 12-01-2003, 01:12 PM
This isn't right, the student CAN'T be faster than the teacher
My goal is a reliable daily driver V6 tbird that runs high 12's
I like the Idea of the smaller Duration higher lift. I'm shooting for as much power/torque as possible while keeping it under 6000rpm redline, probibly a 5500rpm HP peak.
rancherlee is offline
post #23 of 61 (permalink) Old 12-01-2003, 01:35 PM Thread Starter
Uber Luber
Thomas's Avatar
It's true Rancher, you are my teacher. Which is why I'm happy you live in the midwest. I can't wait to meet ya....and beat ya hehe.
-Thomas
Thomas is offline
post #24 of 61 (permalink) Old 12-01-2003, 08:34 PM
T-bird4vr's Avatar
-Thomas
Nah, I went home last week and the old man put me to work. Jack-hammering. Really wasn't too bad though.
Oh, I have an exhaust leak. Can you wield or have one?
julian
post #25 of 61 (permalink) Old 12-01-2003, 08:39 PM Thread Starter
Uber Luber
Thomas's Avatar
yeah I can weld. It's just a matter of convincing my step dad to let me use his welder. Where the leak at?
-Thomas
Thomas is offline
post #26 of 61 (permalink) Old 12-01-2003, 11:11 PM
I guess I have to change my plans now. Can't have a v6 faster then the v8 now can we?
I saw a white bird today with a red stripe in the trim like mine, 91 sport maybe. Have you seen it? I saw it pulling out of the armory parking lot at about 8:10pm tonight.
91 5.0 sport:
M5R2 with B&M ripper, SC seats, 3.27 t-lok rear, 5-4.5 bolt pattern, cobra brakes front and rear, 95 Mustang cobra rims, and open exhaust.
2018 Focus RS
1995 F350 ->Mint
Screwloose is offline
post #27 of 61 (permalink) Old 12-01-2003, 11:32 PM Thread Starter
Uber Luber
Thomas's Avatar
nope never seen it, but I did see a 89-93 white sc today. I thought it was Mike at first but nope, just some old guy as usual hehe.
Oh and you will have a v6 whoopin on you, I promise.
-Thomas
Thomas is offline
post #28 of 61 (permalink) Old 12-02-2003, 04:16 AM
TCCoA Bachelor Club Pres.
92CougLS's Avatar
Eat my good lookin socks slowpoke!
-Kurt
1995 Mercury Cougar XR7
4.6L Bone Stock.
Undergoing a light refurbish
92CougLS is offline
post #29 of 61 (permalink) Old 12-02-2003, 08:30 AM
T-bird4vr's Avatar
cough cough.
Julian
twin screw sc
post #30 of 61 (permalink) Old 12-02-2003, 08:31 AM
T-bird4vr's Avatar
-Thomas
Assuming it is at my crappy weld when I put on my downtubes. I hope the flange isn't leaking but am 90% sure it isn't.
Julian
twin screw sc
