Rough Sounding Starts... - TCCoA Forums
post #1 of 9 (permalink) Old 07-18-2002, 12:12 AM Thread Starter
Tim Groth's Avatar
Send a message via AIM to Tim Groth Send a message via Yahoo to Tim Groth
Question Rough Sounding Starts...
I'm no brain when it comes to the engine bay so any starts are more help than you can imagine. Okay here's what I'm getting. When I go to start my car at the begining of a day be it 6am or 11am the car will turn over and then kinda sound like it's chuggin. Then it takes off and runs smooth as ever. Now it's usually the first turn when this happens but it's happened other times but not as ferquently.
I just had the plugs and wires done because I thought it might be that, but could it be a fuel filter or clogged fuel rail or something?
Tim Groth is offline
post #2 of 9 (permalink) Old 07-18-2002, 09:32 AM
anomnity's Avatar
does it turn fast then stop for a second, then it kinda slowly cranks the engine?
anomnity is offline
post #3 of 9 (permalink) Old 07-18-2002, 05:34 PM Thread Starter
Tim Groth's Avatar
That's it!
I think you hit that one right on the head of the nail. So what exsactly causes this and does it cost more MONEY =(... Thanks
post #4 of 9 (permalink) Old 07-18-2002, 08:24 PM
anomnity's Avatar
mine was a bad battery...
it will start great sometimes and then like shit others...
what causes this is the battery discharges itself sometimes...and cant hold charge..
so i'd get a new battery, or at least get it tested..
anomnity is offline
post #5 of 9 (permalink) Old 07-18-2002, 09:55 PM Thread Starter
Tim Groth's Avatar
No it's not that...
I just put a new bat and alt in like 2 months ago. I know for a fact that it's not that.
Current Collection
1994 Thunderbird SC - Auto
1994 Thunderbird SC - 5spd
1995 Thunderbird SC - Auto
1997 LX - Auto - Parts Car
post #6 of 9 (permalink) Old 07-18-2002, 11:52 PM
anomnity's Avatar
my battery was new too...only 4 months old..so who knows...
just tryin' to help..
anomnity is offline
post #7 of 9 (permalink) Old 07-19-2002, 07:42 PM
Well give the car a good tune up. It will run 100% better. Also somting you sould deffintly check is the timming. A car with bad timming will chug, have poor proformance, hard starts, and sometimes not even start.
Jim
1993 LX 5.0
JSGAuto is offline
post #8 of 9 (permalink) Old 07-23-2002, 02:46 AM
Sounds like the starter motor, ever replace it? How many miles??
3.8_Special is offline
post #9 of 9 (permalink) Old 07-26-2002, 12:03 AM
My 87 Cougar has 350,000 miles on it. It uses mabe a qt. between changes at 3,000.
I use an oil additive that really works. Go get a dictionary and look up Molybdenum Disulfide. Now, go on the web and search for this and try MrMoly. I am surprised that very few people know about this stuff. If you have really good tools they probably say "Chrome Moly Steel" on them. That is because when the steel was smelted Moly was incorporated into the mix. Look, the engine will last almost forever, runs a bit cooler, is noticeably faster, is quieter, uses less fuel. I am getting 28 to 32 mpg on the highway at 70 and 80 MPH. Last run to Toronto (Canada) from my home we averaged 26.8 MPH, and that included about 20 minutes of driving downtown Toronto. Anyway, go look up everthing you can find about Moly. Be careful using some of the artificially made additives. Some crystalize, shale off and score the guts of your precious motor, and you loose about 6 psi oil pressure. I have a '71 Stang and it has a 165,000 miles on it, it sill runs very strong, uses very little oil, and absolutely nothing has been done to the engine other that change ONE valve cover gasket. I can pull 55 mph in first, 93 in second and I have not the courage to find out the rest, but can attest that it will go 130 mph. We pulled a 4000 lb house trailer with it, ran the car pretty hard and still the compression is up and it runs fine. Not bad for a 2bbl 302 Windsor engine. Oh yeah, I have dusted off 350 Cameros and Firebirds. Big shock to there owners. I do have a Haynes tranny cooler. That is it.
Gary is offline
