HeadGasket Pictures - TCCoA Forums
post #1 of 25 (permalink) Old 11-20-2003, 06:45 PM Thread Starter
Thomas A's Avatar
Unhappy HeadGasket Pictures
Well, as if there aren't already enough threads related to Headgaskets in the 3.8 forum, here is another. This is what my Mom's '93 Thunderbird looked like when I tore it down. I'm in the process of replacing the headgaskets. Enjoy:
Hrrmm........ Engine Coffee
Thomas
1989 Cougar XR7 - 13.21 @ 102.29 -SOLD-
1993 Thunderbird SC -Awaiting Suspension-
1994 Mark VIII - 14.85 @ 93.95 -SOLD-
1996 Thunderbird Sport 15.57 @ 89.42 -Retired @ 258k-
1997 Thunderbird LX AED -SOLD-
1997 Thunderbird Sport 15.71 @ 86.89 -SOLD-
1997 Mark VIII LSC 12.97 @ 112.15 -SOLD-
Thomas A is offline
post #2 of 25 (permalink) Old 11-20-2003, 06:49 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Yeah I think it's safe to say the bearings aer fooooocked. That stuff in the pistons is pure coolant! That's like....not good man. Nope. New engine time.
-Thomas
Thomas is offline
post #3 of 25 (permalink) Old 11-21-2003, 02:03 AM
that looked bad and hey Engine Coffee sure i will take some lol not and hey man you got green stuff in the pistons lol i think you need to replace more then just the headgaskets have fun
lowthunder is offline
post #4 of 25 (permalink) Old 11-23-2003, 02:22 AM
What does the oil in the pan look like? I ask because the sludge in the lifter valley may only be from taking the heads off with a cylinder full of water. If, however, all the oil looks like that, you may have serious bearing problems. Was it knocking when you tore it open? If the rest of the oil is ok and it doesn't knock, I would try replacing the headgaskets only (with an oil change) and see how it runs. That's just what I would do ... but if the engine had high miles, I might try to get a junkyard engine and swap it. My engine blew a HG at 96K ... and the first cylinder was full of coolant, just like yours. My oil still looked good, though. I replaced the HGs and it still ticks nicely along at 142K miles.
Oh ... I noticed that the first cylinder is rusty with no carbon build-up, and the other 2 have lots of carbon. I can't really tell where the gasket leaked, but the carbon suggests to me that the last 2 didn't really see coolant until the head came off. Or, if the gasket leaked there too, it was much later than the leak in the first cylinder.
Steve
S_Mazza is offline
post #5 of 25 (permalink) Old 11-23-2003, 09:07 AM
JustinH's Avatar
Wow that looks pretty bad. The 3.8 tbird that myself and my buddy did only had coolant leaking into one cylinder, we must have caught it earlier than this one.
It might be less troublesome for you to find a low mileage wreck 99+ mustang 3.8 and drop that in there if she likes her birdy still.
If you aren't going to swap the motor, at least send the heads out for some milling.
JH
JustinH is offline
post #6 of 25 (permalink) Old 11-23-2003, 11:06 AM
JoeyICU's Avatar
yes thats all in good fun.....if the engine will run later on and keep ticking later keep it....if not.....put a better 3.8 in there adn tell your mom it will give her better gas miledge....cuase it will......would head milling make you lose horsepower b/c it increases piston chamber cc, witch in turn lowers compresion ratio??....im lost on the concept of head milling an n/a car can someone help me?
JoeyICU is offline
post #7 of 25 (permalink) Old 11-23-2003, 12:49 PM Thread Starter
Thomas A's Avatar
In thoery, it would actually raise your compression ratio, but very, very little.
The oil still looks good. I'm going to go ahead and clean up the block, and have the heads gone through, and new valve seals put in. I'll stick it all back together, run it for a couple of minutes, and then drop the oil out.
Thomas
Thomas A is offline
post #8 of 25 (permalink) Old 11-23-2003, 01:51 PM
Thomas, that's a lot of coolant sitting there in the valley and cylinders. Did you drain it before you pulled the heads? It doesn't look like it.
soop is offline
post #9 of 25 (permalink) Old 11-23-2003, 02:32 PM Thread Starter
Thomas A's Avatar
Nope. sure didn't Guess I prolly should of
Thomas
Thomas A is offline
post #10 of 25 (permalink) Old 11-23-2003, 02:38 PM
Ooops. Yup.
soop is offline
post #11 of 25 (permalink) Old 11-23-2003, 10:59 PM
Yeah, I was sort of guessing that the coolant had just spilled onto the lifter valley because the gasket didn't look bad enough to have made all the oil that bad.
And what I said about the carbon buildup or lack of it ... it really looks to me like the only cylinder that leaked was the leftmost one in the picture. But, you would know better than I would, because you can see it in person. I was just thinking that maybe the coolant spilled into both the lifter valley and the other cylinders when you took the head off.
Milling the heads is definitely recommended. I don't know if it's absolutely necessary, but if the car overheated, then it probably is. BTW, when a machinist mills heads, he just puts them on this machine that grinds the bottom precisely flat. Typically, they remove 0.002 or 0.003 inch of metal ... which makes the chambers smaller and slightly raises the compression ratio. I think it would take about 0.6 cc off the chamber volume on the average 3.8 ... maybe a 1% change in volume and CR.
Steve
S_Mazza is offline
post #12 of 25 (permalink) Old 11-24-2003, 08:00 AM
JoeyICU's Avatar
im not geting how it raised the compresion ratio.....wouldnt more cylinder volume mean less presure built up in the cylinder(the compression ratio)?
JoeyICU is offline
post #13 of 25 (permalink) Old 11-24-2003, 01:50 PM
Uber Luber
Thomas's Avatar
when you mill the head you are taking off some of the combustion chamber, decreasing the displacement of the engine. the piston is compressing the same amount of fuel and air into a smaller combustion chamber, rasing the compression ratio.
-Thomas
Thomas is offline
post #14 of 25 (permalink) Old 11-25-2003, 01:20 PM
Boom.
Palmguy's Avatar
You are making the combustion chamber smaller but not the displacement.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #15 of 25 (permalink) Old 11-25-2003, 04:24 PM
JoeyICU's Avatar
oo....ok.....i thought milling involved take off material......
JoeyICU is offline
post #16 of 25 (permalink) Old 11-25-2003, 04:29 PM
Uber Luber
Thomas's Avatar
it does doesn't it? milling the heads is planing then flat. Because when the engine overheats it can warp the flat surface of the head.
Isn't the amount of volume in the combustion chamber the displacement? So wouldn't decreasing the size of the combustion chamber decrease the displacement very slightly?
-Thomas
Thomas is offline
post #17 of 25 (permalink) Old 11-25-2003, 04:29 PM
mamberg's Avatar
it is about taking off material........................to use your cup filling statement in your sig, think of your combustion chamber in the head as an upside down cup, if you mill the heads, it is the same as shaving off the top rim of the cup. Now the cup and the combustion chamber both hold LESS volume.
Piston moves the same distance = same displacement
Forces this into a smaller combustion chamber = higher compression ratio.
displacement is the volume all the cylinders DISPLACE as they move from bottom dead center to top dead center.
PI * R^2 * Stroke * # of cylinders = total displacement
ratio of the displacement of the cylinder to the size of the combustion chamber = Compression ratio.
mamberg is offline
post #18 of 25 (permalink) Old 11-25-2003, 04:35 PM
Uber Luber
Thomas's Avatar
ah that makes sense then. thanks for the explaination. But why does boring the block over increase displacement if it doesn't affect the travel of the piston?
-Thomas
Thomas is offline
post #19 of 25 (permalink) Old 11-25-2003, 04:39 PM
mamberg's Avatar
it affects the displacement of the cylinder because when you take material off the wall of the cylinder, you are increasing the 'R' in the equation, the Radius of the cylinder, (R = 1/2 diameter).
displacement = Pi * R-squared * stroke * # of cylinders
increase any of them (Pi is a constant, that leaves bore, stroke, number of cylinders) and you increase the displacment.
mamberg is offline
post #20 of 25 (permalink) Old 11-25-2003, 04:40 PM
Uber Luber
Thomas's Avatar
oh yeah duh, brain fart. I thought of that just as I hit Post Reply lol.
-Thomas
Thomas is offline
post #21 of 25 (permalink) Old 11-25-2003, 04:44 PM
rustyul's Avatar
Because when you bore the block you increase the diameter of the cylinder. Volume (displacement) equals pi (3.1416), times the radius squared, times the stroke. This will give you the displacement for one cylinder, then you multiply by the number of cylinders to get total displacement.
For example...a 4" cylinder with a 3" stroke would be:
3.1416 * (2*2) * 3 or 37.6992 cubic inches X 8 cylinders = 301.5936 cubic inches
If you bord the cylinder to 4.03 (thiry over):
3.1416 * (2.015 * 2.015) * 3 or 38.2668 X 8 cylinders = 306.1344 cubic inches....
Get it?
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #22 of 25 (permalink) Old 11-25-2003, 05:08 PM
Uber Luber
Thomas's Avatar
yeah I got it already, I've been mindless the past few days. I have to get to a friends funeral visitation soon so I'm kinda out of it. Thanks for the s'planation though
-Thomas
Thomas is offline
post #23 of 25 (permalink) Old 11-26-2003, 01:01 AM
Sorry about your friend, Thomas.
Steve
S_Mazza is offline
post #24 of 25 (permalink) Old 11-26-2003, 01:13 AM
Uber Luber
Thomas's Avatar
Thanks. It was really sad. he was ejected in a car accident and they did a lot of facial reconstruction for open casket. Talk about a tear jerker.
-Thomas
Thomas is offline
post #25 of 25 (permalink) Old 11-26-2003, 07:46 AM
I just removed my 93's old engine yesterday, it was chock full of engine coffee. Im gonna pull the heads and see whats inside.....
JohnNaas is offline
