Thermostat Housing bolt. - TCCoA Forums
post #1 of 4 (permalink) Old 11-26-2003, 09:10 PM Thread Starter
The subject: 96 Cougar w/ 3.8
Need: specs on the thermostat housing bolt. Length, thread type, etc, etc.
Kenneth
wkenneth is offline
post #2 of 4 (permalink) Old 12-01-2003, 10:02 AM
Trumpeter Extraordinaire
IronChopz's Avatar
Check if this helps any...
IronChopz is offline
post #3 of 4 (permalink) Old 08-31-2004, 04:11 PM
Sorry to hijack an old thread. I installed my replacement thermostat today, and it is the same temp as the old one (195) except when I tried to screw it in and lock it in place, it did not seem to want to do so. I put a little silicone around the edges and that held it in place while I installed the gasket. Then I held it up against the inlet and screwed the two bolts back in. Is this acceptable or not? I can just as easily take it off and do it again, maybe trying a different brand if necessary. The brand I just installed was a STANT that came up as stock for a 1994 3.8 n/a at Pep Boys. Any advice? Thanks for your help in advance.
kingcrab is offline
post #4 of 4 (permalink) Old 08-31-2004, 06:49 PM
It is nice
thats fine the way you did it, and the stant doesnt lock the purpose of the locking is to align the vent hole at 3 or 9 o clock which im unsure which models (or brands of stats) use this type of stat or not - my 91 cougar i got a stant one you can always drill the hole which does have some benefits but youre ok like that http://v6.redpony.org/howto/thermostat/tstat.htm thats a good article for the 3.8 install.
91CougarLS is offline
